Big cams little Turbo
The last batch I bought were 274/274 (the same ones in my car) 11.2/11 and 115* centerline on the exhaust cam (I have a IX) The new ones as you pointed out are sposed to be more lift and more duration on the intake but I am not sure on release date. I was hoping to get 2 sets of them but Greg hadnt got billets in when I ordered
Oh well I know the 274/274 make great power (also the ones Luke has actually...but for an VIII)
Oh well I know the 274/274 make great power (also the ones Luke has actually...but for an VIII)intake 278 and exhaust 274 with 11.2mm intake and 11.0mm exhaust lift
S2s and FP Beehives work very well for me and I have sold many sets. The stock retainers are very light and work very well. The FP beehives are rated to mid 8k for rpm with aggressive cams and I have no doubt they could do more, though I dont suggest it since I was told they are rated to 8500 or so and havent pushed them personally.
Have you used the GSC Beehive springs or are they the same as the FP springs?
http://www.stikiller.com/product.php...cat=335&page=1
Part number 5039 includes a set of GSC Beehive Springs for use on the stock seat and OEM retainer. This kit is capable of 8500RPMS (or south of 9k), with as much as 11.4mm of lift (or .259" of camlift). These are designed as a drop in spring to use with the S2 camshaft set.
Spring pressure:
Seat at 1.56"= 68pounds
.300"= 160 pounds
.400"= 210 pounds
CoilBind .625"
Max lift 11.4mmof lift (or .259" of camlift)
Yes and No... Its still alot of lift on the stock spring and over time could be detrimental. Its cheap insurance to at the minimum change out to a beehive spring like the FP's or the GSC springs.
any updates on the gsc S2 cams on a ix? I havn't seen any decent reviews on these cams going into a ix making more power without upping the boost to 25 26 psi.
The 278/274 S2 ("new grind") cams definitely perform. They have been tested in 2 customer cars at various boost levels and both on E85 to get an idea of results. Thomas (EvoTK) put down 439whp at 29psi on a stock turbo and Jim made 546 at 31psi on a Red.
well i have seen a few threads where there were back to back comparisons. Say stock turbo stock cams at 20 psi made 300 hp, then s2s were installed, boost was raised to 25 psi and made 330hp. Obviously power was going to increase with 5 extra psi. I just dont want to spend 1500 dollars on cams, springs, and install and make 15 extra hp. Im already running 25-27 psi. I know your a big advocate on gsc cams so i figured i would ask you because you seem to know them best. 8s make great power increases with cams but i feel like ixs don't see as big of results with them, at least on the stock turbo on 93 octane for a normal bolt on car.
I guess that's not to bad and actually what I was hoping you would say. I'm really hoping to get a set of the new S2s in the future because I think they may shine with the SST turbo I have installed. After a bit more testing with this unit I may consider cams if I'm not satisfied with the power. thanks for the help John!
JB,
Do you still feel the S2 cams are the ones for IX owners? There are so many choices within one another. I know you've answered this many times before in this thread, but now that some time has passed i just wanted to know how you felt.
