The baddest EVO 9 pump gas we've built.
Old Apr 23, 2008 | 09:01 PM
  #46
Indy Evo's Avatar
If I drove it I'd want one . You will always be 100+HP ahead of me
Old Apr 23, 2008 | 09:05 PM
  #47
evo_8_u's Avatar
good job dave!!!!!
Old Apr 23, 2008 | 09:27 PM
  #48
SloRice's Avatar
Awesome numbers Jeff! Can't wait for the 3 white 550+whp Evo's to go 3 wide with the video camera's rolling!!
Old Apr 23, 2008 | 09:31 PM
  #49
Invoice EVO's Avatar
Veteran: Air Force
Hey...hey...why does it have to be the white EVO's? Why can't I be in the mix with my silver EVO? We can make it four wide.
Old Apr 23, 2008 | 09:32 PM
  #50
scheides's Avatar
EvoM Moderator
vwjeff, what was it that made you decide to do a full build on this car, when it was well setup to begin with? You had a 35R(non HTA if I recall?), you had all the other bolt-ons, buschwacker trans, etc. Why not just build the motor and keep on trucking? Maybe do an HTA upgrade while your car was down? Instead of doing motor, trans, new turbo kit, etc etc etc...
Not knocking your build man, its bad ***, just curious as to your motivation!
Old Apr 23, 2008 | 09:39 PM
  #51
dxbevo9's Avatar
SIIIIIICK NUMBER JEFF!!!! i might send my car to david to build it and tune it...looking for shipping quotes!
goodluck
Old Apr 23, 2008 | 09:59 PM
  #52
vwjeff's Avatar
Indy you wont be able to resist it Who else beside maybe Buschur would let you drive there cars?
Tim the problem is Eric... he just to far away But I am sure we can get all 4 of us together for some roll! Remember what David said before....
https://www.evolutionm.net/forums/sh...19&postcount=4
scheides... I upgraded everything cause the car wasnt gonna get much faster the way it sat... to an extent. Sure AEM, lighter brakes ect would have helped. But I just wanted more, I am a SPEED freak just like everyone else on here. I had an R1 that was getting me in ALOT of trouble with the law in 3 years. And if it wasnt that I was gonna kill myself on it.
I sold the bike to help fund my dream (no joke) a Buschur Built Race car I could drive everyday, and Team Buschur has pulled through for me with flying colors.
Next up will be an AMS CF roof, and lighter brakes, but I want BR's insight for the brakes
Old Apr 23, 2008 | 10:03 PM
  #53
evovin's Avatar
Awesome Jeff!!!
But why did you only go with 65mm TB why not 3 inch TB?
OT:
BTW.Nick just called me today and said that my HTA88 is there now and just waiting for the back housing from FP!
Old Apr 23, 2008 | 10:06 PM
  #54
SLVRNBLK's Avatar
Veteran: ArmyFCOTM Winner
Awesome build, congrats! I see a roll cage in your future
Old Apr 23, 2008 | 10:53 PM
  #55
JC evo1's Avatar
Originally Posted by davidbuschur
Today was an interesting day. We put Jeff's car
awesome power on pump, congratulations
What rpm will you be revving to on the track, looks like power wouldn't start falling off till at least 9500?
Old Apr 24, 2008 | 05:49 AM
  #56
vwjeff's Avatar
Originally Posted by evovin
Awesome Jeff!!!
OT:
I will change to a 3in t-body when David finds me a better set of ix cams.
I believe that DI or Trent at Buschurs can change out the flange for me down the road.
A 3in t-body and m3 cams may have put me over 600 on pump?
Old Apr 24, 2008 | 05:51 AM
  #57
4G63DSM's Avatar
How much lighter are the alum rods?
Less weight ought to make a smoother engine....
Any of these cars still have the ballance shafts???
Old Apr 24, 2008 | 06:26 AM
  #58
David Buschur's Avatar
NO engine we build uses balance shafts, ever.
When we dyno the car on Friday on race gas the maximum RPM will be determined then. The problem with RPM and boost is the more you want of each the sooner everything wears out. Having thoughts of a 600 whp EVO that you run at 10,000 rpm everyday sure sounds cool, in reality it is an expensive dream.
I layed Tim G's dyno graph over Jeff's. I was absolutely 100% shocked at what I found. There really isn't a lot of difference in the curve. I then layed Eric N's dyno graph over them and found the same to be true. Eric's car had the best mid range but not a big difference. The curve's are suprisingly "close".
My mind is freaking out on me right now over this chart I am going to post. Here are some specifics on both turbos for boost response:
HTA35r HTA88
10 psi 4234 rpm 4547 rpm
15 psi 4473 rpm 4820 rpm
20 psi 4680 rpm 5039 rpm
25 psi 4852 rpm 5273 rpm
28 psi 5023 rpm 5379 rpm
It's amazing what a difference that extra 300-400 rpm in spool up make in the feel of the car on the dyno. To be honest, I thought this turbo was an absolute turd by what it felt like on the dyno. Now that I have compared the two charts I have to re-think that. It's really not far off from the HTA35r.
This car should easily trap over 135 mph on pump gas.
Here's the two sheets for comparison:
Old Apr 24, 2008 | 06:40 AM
  #59
evovin's Avatar
Wow Dave!!! I can't wait for mine now. I know it won't be the same power level with Jeff... but I know I will be contented with this than the HTA35R. I am assuming that on fridays test will be better/makes more power than the other test.(of other shop) Im not against with them but I am just more confident on you!
I wish you have a pics of side by side of HTA88 and HTA35R?
Old Apr 24, 2008 | 07:00 AM
  #60
SPIN2GST's Avatar
Jeff, I'd be willing to make the 2hr drive for some 3 wide action. I've been meaning to head down that way to check out my buddies new condo for while now.
Lets set this up!
