Gt35hta on a stock block
Old Apr 27, 2008 | 05:17 PM
MidnightEVO's Avatar
Thanks everyone for all the useful info and support. Best of luck with your builds. I agree 480whp is the max id feel comftorable with on stock internals and then you have the axles to worry about as well. Id like to run low 11's on pump and stock block so I believe the HTA will be the way to go...
Old Apr 27, 2008 | 05:21 PM
Jspec EVO VIII's Avatar
Here's a good question, anyone done it w/a built block but unported head?
Old Apr 27, 2008 | 05:39 PM
4G63 T's Avatar
Originally Posted by alwaysboostin
y do people have to b such dicks on this forum, probably y I don't post much, is it that difficult to say yes mellon was on a completely stock block that took about as long as saying "search first" or whatever else the dick heads decide to say
....or do they have one?
Old Apr 27, 2008 | 05:45 PM
EVOlutionary's Avatar
Originally Posted by Tarmacisback69
yea i wouldnt go over 480whp on stock block.
What are you basing this on? Specifically, what experience or data have you used to formulate this statement?
Old Apr 28, 2008 | 10:41 PM
TurboRSX04's Avatar
if i was to run no more 25 psi on the hta35r, will the stock headstuds be alright?
Old Apr 28, 2008 | 10:45 PM
Johnboy1065's Avatar
i'd say not. because with even a stock turbo running 26-28 lbs it gets risky running stock head studs. and the 35r running at 25 lbs is a lot more air than 26-28 lbs on the stock turbo
Old Apr 28, 2008 | 11:17 PM
dxbevo9's Avatar
Originally Posted by 4DR
He has AEM and every single bolt-on made for the EVO
he is on stock ecu..and he has the standard bolt ons...stock intake mani..stock throttle body.
Old Apr 28, 2008 | 11:25 PM
Import Junky's Avatar
Interesting well maybe I'll be a victim of this 500whp stock block issue. My kit will be ordered once I get off of night crew in about 4wks and I'm going HTA35R/GSC S2 cams and pushing just over 500 to the wheels. We'll see how long she holds, it's not like a don't plan on building the motor anyway.
Old Apr 28, 2008 | 11:28 PM
dxbevo9's Avatar
check out my thread in this forums called HTA35R first impressions..i am running stock block/ecu...however with every single bolt on that could cross your mind.
Old Apr 29, 2008 | 12:02 PM
Mellon Racing's Avatar
here are my current mods...keep in mind I made 500awhp before the ported intake and throtte body with 880cc injectors + kenne bell boost a pump (maxed out 110% IDC)
If you're going over 500awhp 1000cc and a twin pump are necessary
BR HTA 35R 5 bolt .63 @ 30psi on 93 octane
HKS 280 cams
PTE 1000cc injectors (necessary for over 500awhp)
BR twin walbro fuel pumps (necessary for over 500awhp)
BR 3" tbe, test pipe, bullet muffler
BR 3" intake pipe + Mas adapter
BR UICP
BR Mini Battery
BR Race FMIC
ARP head studs
PPI ported stock intake manifold
PPI 65MM throttle body
Exedy Twin Disc HD clutch
My tuning www.mellontuning.com
coming soon:
BR 2.0 shortblock
BR BF272 cams
Springs/Retainers
C16 tune
latest DLL, it was in the 535 awhp area when it was 30* outside but it's more like 80* outside now.
Old Apr 29, 2008 | 12:06 PM
TurboRSX04's Avatar
HKS 280 cams
BR UICP
BR Mini Battery
BR Race FMIC
ARP head studs
coming soon:
BR 2.0 shortblock
BR BF272 cams
Springs/Retainers
C16 tune
mellon, you have any new race videos? also i thou u had the .82 i didnt know u had the .63. in that case i might get the .63 then.
Old Apr 29, 2008 | 12:09 PM
there's a little something going down the 9th and I'm going to try like hell to hit the track for the first time on this setup this Thursday night, hopefully the planets align and I can go.
Old Apr 29, 2008 | 12:19 PM
Gleason at STM's Avatar
The Street Tuned Evo has had over 500whp on stock motor for 2 full seasons of racing here, though not on an HTA 35R. Ran a slowboy .63 35R kit with HAFE manifold; Stock motor with studs and cams. Over 40,000 miles on the motor and its holding up great. At the last track day of the season here, Emery got it to go 10.68@134.5 !
http://www.streettunedmotorsports.com/gallery.htm
http://media.putfile.com/StreetTuned...on-stock-motor
Old Apr 29, 2008 | 12:24 PM
4WS Tuning's Avatar
500whp is very doable as long as you have all the parts to compliment the turbo.
Cheers!
Arandhawa23
13
Jan 3, 2013 07:28 AM
S13 Curtis
Apr 11, 2011 11:08 PM
btownsoccer22
Aug 25, 2009 07:19 PM
dsm25psi
27
Aug 25, 2008 11:35 AM
evoboy83
96
Aug 1, 2008 10:38 PM
