Stock IX boost reading on OEM gauge?
Old Apr 28, 2008 | 09:54 AM
Bounty Hunter's Avatar
I haven't driven my car for awhile (it was in storage and we had a long winter). I was wondering what the stock boost is on my IX RS as it reads on the OEM gauge (3 gauge pack in the dash). I think that my car isn't boosting to it's normal potential, but I could be paranoid. I posted other threads here in the n00b forum and I haven't had any help (yes I also searched).
What is normal boost levels as they read on my OEM gauge in bar? The highest I'm hitting is 1.2 bar and then it will taper to 1 bar. From my research that's pretty low. Shouldn't I be spiking closer to 19-20 psi (1.4-1.5 bar)?
I checked all my lines, hoses and clamps and everything seems tight. Thanks for any help.
Old Apr 28, 2008 | 09:57 AM
inco9nito99's Avatar
OEM gauges are not very accurate at all.
Old Apr 28, 2008 | 10:00 AM
No.9's Avatar
It should spike to 21psi (roughly 1.4bar) then taper to about 17psi (roughly 1.1). Are you tuned? Do you have a MBC or EBC?
Old Apr 28, 2008 | 10:06 AM
No.9's Avatar
I wouldn't say "not very accurate at all". My OEM boost gauge is pretty much dead on. It spikes to 1.5bar which is exactly where my tuner set my MBC (22psi=1.5bar). As far as oil temp or voltage, I haven't tested or compared anything to them, if that's what you're referring to.
Old Apr 28, 2008 | 10:16 AM
slicedbreadno2's Avatar
Oem gauges are very inaccurate.
Old Apr 28, 2008 | 10:49 AM
No my IX is completely stock. I do have a K&N panel filter right now. Before that I tried out a MAF adapter + K&N cone filter and I removed it. It seemed like I was hitting lower boost with that setup as well.
Since most of you think the OEM gauge is inaccurate, should I not be concerned?
Old Apr 28, 2008 | 11:17 AM
Jer.k's Avatar
my car bone stock peaked 1.3 bar in 4th which is a same as all the other evo 9's w/ oe gauges...seems to be accurate.
Old Apr 28, 2008 | 11:25 AM
EvoBroMA's Avatar
4th should be spiking to 1.3 and taper down to 1.1 or less.
i found the stock guage to be about 1 PSI off from my (calibrated) JDM map logs,
and its completely useless if your spiking 22-23psi.
Old Apr 28, 2008 | 12:40 PM
So what do you guys recommend? Get a new boost gauge?
Old Apr 28, 2008 | 12:53 PM
^^^ Yes.
Old Apr 28, 2008 | 12:55 PM
EvoBroMA's Avatar
alot of gauges are off by one PSI (even expensive DEFIs), so its really up to you.
Old Apr 28, 2008 | 01:15 PM
Maybe I shouldn't have tore that entire plastic tray off. I'm willing to bet that took longer than installing a TBE after looking at things last night.
Even if I am boosting a little lower than normal I guess that will all be irrelevant once I get a reflash and TBE right? (as long as I don't have any leaks)
Old Apr 29, 2008 | 07:24 AM
Old May 4, 2008 | 07:53 PM
BUMP...
I was messing around with the car tonight a little and it would peak between 1.2 and 1.3 in 4th according to the OEM gauge WOT from 2k RPM or so. Maybe I'm just being paranoid. It's just that I've got different people telling me different things. I just want to make sure things are right before I start modding my IX.
I'm sure it's normal to get lower boost if I'm going WOT and shifting quickly between gears. The engine can't fully spool up the turbo...right?
Old May 4, 2008 | 08:10 PM
Evoardo IX's Avatar
OEM gauge reads in kg/cm2 wich is pretty close but not the same as bar. My gauge reads 1.2 kg/cm2 then goes to 1, in fourth and fifth gear it goes to 1.3 and slowly goes down to 1.2 and pretty much stays there. I was told that the kind of fuel you use affects the boost you get, down here in Ecuador I get 92 RON. So I think both your car and gauge are just fine
CO_CReX
Mar 18, 2017 11:19 AM
EVOIX-SAV
26
Mar 13, 2017 02:16 PM
EvoIIIAj
Nov 14, 2013 12:59 PM
MrJuls
Sep 20, 2012 03:08 AM
robyn402
Sep 12, 2010 11:43 PM
