Cam install problem on my new stroker
Old May 9, 2008 | 10:28 PM
2theMAX's Avatar
For the past few days I have been trying to get my cams working properly on my EVO 8. I had the motor built/stroked and assembled. We installed the head and all the accessories with a new timing belt, etc. The problem has happened when I installed a set of new JUN 272's. I used several write ups and watched the video too. Everything went fine except for when I turned the crank to make sure everything rotated peoperly and didn't bind. Well, it would turn 1/4 turn and stop. I actually tried pretty hard to turn it further, but it wouldn't so I stopped as not to force it. I know that everything is still in time. I checked it all and rechecked it again. Thinking maybe it was the cams, I removed them and installed the stock ones. Same exact problem! I decided to take out the rockers and see if the cams turned smoothly and they did. What do I do? Should the dual valve springs be that stiff that it feels like the cams are binding? I don't know what to do next. What could be the problem? Thanks.
Old May 10, 2008 | 09:46 AM
Tuner@Swift's Avatar
Was the crank/block clearance OK? Some blocks need to be notched a little bit to clear the crank counterbalance. Did the crank spin fine before you put the head on?
Old May 10, 2008 | 11:00 AM
2theMAX's Avatar
Everything spins fine with the rockers removed. It's with them installed that I get the binding.
Old May 10, 2008 | 04:00 PM
2theMAX's Avatar
I figured it out. I guess I was not turning everything hard enough against the dual valve springs.
Old May 10, 2008 | 04:11 PM
bluebyu36's Avatar
nice
comced
Apr 11, 2016 08:53 AM
SR Concepts
Jun 7, 2015 01:24 PM
heel2toe
46
Mar 24, 2015 04:17 PM
Johnboy1065
22
Sep 17, 2005 12:36 PM
gadsmevo
Mar 2, 2005 07:37 AM
