Innovate Db AFR gauge issues
You don't need the red button to calibrate it because I didn't use it to recalibrate mine. Look at the link that 4kinboost posted for the LC-1 and do the initial calibration over again.
Alright I read the directions and how to do the initial Calibration. Since its already installed I simply need to take the sensor out, then disconnect the sensor from the lc1, then give it power. Can I just turn my accessory on with the key to give it the power it needs??
Well i found out what my problem was.. My analog output 2 was putting out 10 volts insted of the normal 5 volts, so I turned the volts down to 2.45 max and it is working fine now..
03Ev0luti0n
May 16, 2011 07:27 AM
JYD
Nov 29, 2010 08:57 PM
