typical post turbo charge air temps
Old May 11, 2008 | 01:19 PM
clip14's Avatar
Hi has anyone measured the temperature of the charge air directly after the turbo? (i.e. after the air has been compressed by the turbo, but before the intercooler - where the charge air would be it's hottest)
I am specifying some materials which need to be able to handle the temperatures generated by the compression of the charge air and need to know what ball park temperatures I should be accommodating for.
Thanks
Old May 11, 2008 | 08:28 PM
dubbleugly01's Avatar
PV=nRT. That should get you in the ballpark. Add 10-20% as a safety factor for the heat picked up from a hot center section.
Old May 11, 2008 | 08:54 PM
clip14's Avatar
Thanks for the reply,
can you please define your variables? It's been a while since I've done any thermodynamics
Old May 11, 2008 | 09:45 PM
spdracerut's Avatar
(P2/P1) = (T2/T1)^(k/(k-1))
Where the pressures and temperatures are in absolute values, and k = ratio of specific heats = 1.4 for air. After you solve for T2, divide (T2-T1) by the efficiency of compressor, so about 0.70. Then add that value to T1. That should get you close.
So for 1.4 bar of boost, (we'll say 1 bar = 1 atm for simplicity), P2 = 2.4 bar, P1 = 1bar, T1 = 295K (~71F).
T2 = ~379K. T2 - T1 = 84. 84/0.70 = 120. So the final temp is about 120+295 = 415K or 288F.
Old May 11, 2008 | 10:42 PM
94AWDcoupe's Avatar
I have measured around 5 different turbos. The bigger the turbo the cooler the air will be. The higher the boost the hotter the temp will be. What size turbo and boost level are you running?
Old May 11, 2008 | 11:37 PM
clip14's Avatar
fairly small turbo for now only running standard boost (10psi)
td04-13g on a 1800cc motor.
Old May 12, 2008 | 05:52 PM
94AWDcoupe's Avatar
around 225 degrees.
Old May 13, 2008 | 01:05 PM
clip14's Avatar
thanks for the replies.
I'm planning on using some hose for the charge piping and it's rated to 212 degrees farenheit.
i know the charge air will exceed this temperature during full boost etc, but this is not (yet) a dedicated race car... so the amount of time spent on boost will most likely be intermittant.
Old May 15, 2008 | 06:32 PM
I was being a bit of a smarta$$ in my first response. I apologize for that. Follow this link, it will help explain/calculate what you're looking for. About 3/4's of the way down the page.
http://www.enginelogics.com/cmaps.html
Old May 15, 2008 | 07:27 PM
GrocMax's Avatar
A large portion of you boost junkies drive them right off the top and right side of the comp maps, spend very little time in any area of decent efficiency, regardless of turbo size. Not that it matters much with modern IC's. Think 430-450+K. 350+F.
Old Feb 15, 2023 | 07:28 AM
bn880's Avatar
Exclamation
<just misread equation>
Old Feb 15, 2023 | 05:41 PM
deylag's Avatar
Originally Posted by bn880
Wrong
T2 / T1 = (p2 / p1) ^ [(gamma - 1)/gamma]
you had the gamma bit reversed
Ah I see Isentropic Compression. However this is unfinished and you need to solve for T2 only. I feel like I need to give you a chance to finish what you started.
Using the values in post #4 where gamma is equal to 1.4 since that is ratio of the specific heats of air solve for T2.
Old Feb 16, 2023 | 07:05 AM
bn880's Avatar
Old Feb 16, 2023 | 07:54 AM
240Z TwinTurbo's Avatar
Instead of debating theoretical calculations just stick a temp sensor post turbo, which I have done in the past. Somewhere on this forum that data exists for the GTX3576r.
Old Feb 16, 2023 | 09:47 AM
griceiv's Avatar
You're welcome smartass. I'm correcting misinformation and am not working for you.
you aren't correcting misinformation, you are just proving you suck at algebra. the equation you posted and the equation in post #4 are the same just solved for different variables.
