Shifter Bushings
Old May 31, 2008 | 09:26 AM
  #31
EvoJoeIX's Avatar
you know i never did adjust the clutch pedal. i didnt think i had to since as soon as i put the stockers back on, everything was really smooth again. maybe i will try to put them back on one day and adjust the clutch for it
Old May 31, 2008 | 09:37 AM
  #32
WRC-LVR's Avatar
I used the ones from SpeedSource.net specific for the MR 6 spd. Brass. I installed with a little lube. Works great. Shifter has much more precise feel for 2,3,4,5,6. Highly recommended. I did remove the battery tray for the install, its just a lot easier that way.
I also installed their console bushing set. Not sure if that really made a difference since the whole base is plastic. Their bushings are aluminum. Install was straightforward .
Milburn
Old May 31, 2008 | 01:40 PM
  #33
Burklow's Avatar
Originally Posted by EvoJoeIX
^^^ they were buschur shifter bushings by the way
just so you guys know
I had to drill mine out so they'd actually fit.
Old May 31, 2008 | 09:07 PM
  #34
EvoJoeIX's Avatar
mine slid right on no problems, the only problem was the shifting problems...
how much did you have to drill out of them?
Kracka
83
Jan 20, 2017 12:54 PM
nor11384
Mar 28, 2016 05:11 AM
StormTroperX
Jan 26, 2013 11:23 PM
TWM Performance
Jul 1, 2010 01:43 PM
Grey Razor
17
Nov 18, 2006 05:22 PM
