Oil leaking from my exhaust mani gasket
Old May 15, 2008 | 12:34 PM
IDRNKV8's Avatar
Unhappy Oil leaking from my exhaust mani gasket
Ya, this sounds ridiculous, but its happening. I know, I know, oil shouldnt be there, Im no noob to working on cars, believe me on that one, but w*f?? Bad rings seems to be the first impression, but then again, Im makin great power....Any other suggestions than just a compression test? (just noticed this a few days ago, and havent had time to look into it). Anythings appreciated, thanks
Old May 15, 2008 | 12:38 PM
Nez136's Avatar
hmm, do you have a catch can/s? you can see how much blow by you are getting from there. Are you blowing out the dip stick? I would just run a leak down test on all the cylinders. Seems off, are you sure that the oil is coming from the mani gasket???
Old May 15, 2008 | 12:43 PM
Markley02's Avatar
Bad exhaust valve seal would cause oil to leak into the exhaust manifold. Bad rings would put the oil into the combustion chamber and be burned resulting in smoke, not visable oil.
Edit: After thinking about it again and reading Nez136's post; If you are getting a lot of blow-by and there is something up with your PCV valve (maybe catch can if you have one) it might be enough pressure to push the oil past the valve seals. I would tend to think that your dip stick would be poping out and you would have blown your valve cover gasket by then though.
Old May 15, 2008 | 12:50 PM
Smike's Avatar
Could the oil be leaking from the valve cover gasket? Or is it exhaust 100%?
Agree on testing more.
Old May 15, 2008 | 12:58 PM
IDRNKV8's Avatar
Positive. It rests on my manifold flange. I just had the head completely redone tho, valve seals and all.... Hmmmmm. And yes, I do have a catch can
Old May 15, 2008 | 01:00 PM
IDRNKV8's Avatar
110% its from exhaust. Head is cleeeaaaannnnnn
Old May 15, 2008 | 01:04 PM
chris164935's Avatar
Bad oil seals on the turbo? What does it look like when you take off the inlet pipe to the compressor housing?
Edit: Just realized you said exhaust manifold. Does your exhaust manifold leak exhaust gases? Pretty sure oil shouldn't be able to leak from it if exhaust gases aren't leaking from it... Oil spraying from the catch can vent?
Old May 15, 2008 | 01:38 PM
IDRNKV8's Avatar
Its clear its from the exhaust mani. I have a mynes tubular mani, and inbetween the runners, the flange swoops down. The oil is accumulating there. Catch can is on intake mani side (in front of alternator).
Old May 15, 2008 | 01:42 PM
Smike's Avatar
Get oil dye and UV light. Going to have to find the source.
Old May 15, 2008 | 01:45 PM
Oil drain line from the turbo possibly? Can you take any pictures of the area?
Old May 15, 2008 | 01:54 PM
TalonTuner4G63's Avatar
Do you think that oil will actually stay in a liquid form if it was leaving the combustion chamber into the exahust manifold? Negative.
Check the exahust manifold studs, pretty sure at least one or two of them protrude into an oil gallery of some sort.
Old May 15, 2008 | 02:12 PM
IDRNKV8's Avatar
Thats true, didnt think about that one. Its not actually dripping off tho, its just leaking a bit.... I can get pics maybe later on tonite
Old Sep 13, 2008 | 09:08 PM
LV///R's Avatar
Old thread, I know. But it seems I'm having the same situation.
I think I've got an exhaust leak from where the exhaust manifold attaches to the engine. It seems like there is a bit of oil sitting on the top of the flange of the exhaust manifold...
What'd you find out?
Old Sep 14, 2008 | 05:20 AM
revvin9k's Avatar
https://www.evolutionm.net/forums/sh...d.php?t=368255
Old Sep 14, 2008 | 09:03 AM
SlowSRT03's Avatar
When you got everything redone, Did they check or replace the rings? There shouldn't be that much oil coming out of your exhaust mani gasket where you can actually see it. Also like someone said before, did they replace the valve seal or just try to "refurbish it". If your getting work done make sure you know your stuff before taking it to the shop and not assume they know what they're doing.
_des_
Feb 7, 2017 07:13 PM
bikerbud76
Feb 7, 2014 12:58 PM
ViciousLSD
Jan 2, 2012 11:32 PM
lockadam2112
Oct 4, 2009 06:29 PM
projekt_shocker
Mar 15, 2006 05:58 AM
