Turbosmart boost controller with AQ HSF-1
Old May 19, 2008 | 07:26 AM
nikkadanny's Avatar
OK after getting my meth kit tuned with the hallman mbc we only could get it to run 28psi max. I had a turbosmart mbc the newer style in my brothers turbo teg so i switched it out and now im able to up 28psi and up i havent had the time to up it more but the mbc still has alot to go. But the thing is that on the hallman i were to turn off the meth kit then im running off the wastegate 11-12 psi, but with this mbc off the meth it runs like 19-20 psi why is that and is it safe?
thanks
Old May 19, 2008 | 07:46 AM
KevinD's Avatar
weird, thats definately not right. with the meth off you should be at wastegate because the failsafe valve bypasses the boost controller completely. lets do a boost leak test on it for the throttle body issue, and at the same time we can look at the vacuum lines. i suspect somethings not right.
Old May 19, 2008 | 08:07 AM
nikkadanny's Avatar
can i stop by today kevin?
EvoLucio
Mar 9, 2016 09:42 PM
My03evo
Aug 29, 2011 11:04 PM
ArchieBabes
Evo X Dyno Results
Nov 17, 2008 10:39 AM
fastassfourdoor
May 19, 2008 09:47 AM
90GSXDan
15
Jan 22, 2008 01:23 PM
