Cosworth M2 and MR 02 Housing got 1 extra HP????
Old May 21, 2008 | 12:38 PM
  #46
YzBrad99's Avatar
So far no results back yet.
Old May 21, 2008 | 01:40 PM
  #47
mudduck's Avatar
sorry to hear about no gains with the Cossies. I had the same exact thing happen when I had the S1's installed - gain of <10whp (peak) with a loss of low-end torque. I swapped over to the Cossie M2's and made noticeable gains throughout the powerband.
Yes, the Cossies are supposed to come in 2 separate blue plastic boxes. I can't remember fully, but I'm pretty sure both cams should have the cosworth etching...
Good luck...
Old May 21, 2008 | 02:02 PM
  #48
Shacochis06's Avatar
i thought the cosworths that came in the blue bag had problems...and if u received them in the blue package that you needed to send them back to cosworth and they would replace them for you
Old May 21, 2008 | 04:13 PM
  #49
YzBrad99's Avatar
Old May 21, 2008 | 04:14 PM
  #50
YzBrad99's Avatar
Thats the difference from before the cosworth M2 272 and before the 02 Housing, and after.
14.08 ft/lb Torque
1.54 Hp Gain
Old May 21, 2008 | 04:16 PM
  #51
Wicked E's Avatar
Do you mind if I hit you up on AIM?
-E
Old May 21, 2008 | 04:27 PM
  #52
raiceboi697's Avatar
hmm thats weird when i got my cossies installed they were hella agressive and now my car pulls crazy hard. something jsut aint right.
Old May 21, 2008 | 04:29 PM
  #53
YzBrad99's Avatar
Old May 21, 2008 | 04:33 PM
  #54
Gary@MellonRacing's Avatar
did u call they guy who sold them 2 u
Old May 21, 2008 | 04:52 PM
  #55
o-townFLA's Avatar
heres my graph with an before/after comparison. How many times did they pull your car for the final tune? I'm sure they wouldve seen this and adjusted the values alittle for better top-end. If all else fails ask for a re-tune
Both of my cams came in blue cosworth labeled two-piece tube boxes.
good luck
Old May 21, 2008 | 05:06 PM
  #56
YzBrad99's Avatar
Old May 21, 2008 | 05:33 PM
  #57
No.9's Avatar
??? Can you elaborate on this please.
Old May 21, 2008 | 05:43 PM
  #58
No.9's Avatar
My dyno results BEFORE installing Cosworth M2's - 314whp 309ft-lb
My dyno results AFTER installing Cosworth M2's - 310whp 325ft-lb
Old May 21, 2008 | 05:57 PM
  #59
No.9's Avatar
I'm starting to see a trend, I guess I'd like to see more graphs. So far all of us are right around the same #'s considering the different dyno factors.
Old May 21, 2008 | 05:58 PM
  #60
RazorLab's Avatar
Originally Posted by No.9
My dyno results after installing Cosworth M2's
Worthless without a before/after overlay. Have that?
