Cosworth M2 and MR 02 Housing got 1 extra HP????
Old Dec 3, 2009 | 06:01 PM
  #106
kaj's Avatar
kaj
Originally Posted by YzBrad99
I gotta 7800 rpm rev limiter and the stock turbo falls off its face at 7000 rpms, no need to rev any higher unless you gotta bigger turbo.
it sounds like that is your issue then. no matter what cams you run, you are gonna end up with "not much power" at peak. right??
so.. you need a bigger turbo to take full advantage of the cams?
