ATP Turbo kit Dyno results,,,,
Old May 21, 2008 | 11:25 PM
4kinboost's Avatar
I wanted to take the time to thank Shameless Tuning for helping me set-up the parameters that I needed to get things going.
93+ 3 gallons of 100oct mix
Atp gt3076r
cosworth 272's
3" tbe WITH CAT
dual waly's, -8line, perrin fuel rail
Stock motor
Stock head
Stock intake manni and tb
unported anything
Stock ECU
SUPER CONSERVATIVE PUMPGAS TUNE. It only took me 10 pulls to add 100awhp. 0 knock of course.
As soon as I work out the final bugs (boost leak) and throw some c-16 in the tank, I'll be going back for the 500awhp print-out.
There's so much left in this turbo. I think I can crack 530-550 with AEM-- but I like the idea of a stock ecu/catted/no roll cage 500awhp car.
I guess this is the point when the ATP bashing begins?
Old May 21, 2008 | 11:29 PM
dudical26's Avatar
Congrats, those are good numbers. Although it seems like you went a bit overboard on the fuel system. What size injectors are you running? I can't imagine you really need dual walbros and -8 fuel line.
Old May 21, 2008 | 11:30 PM
Warrtalon's Avatar
We'll see.
Old May 21, 2008 | 11:35 PM
4kinboost's Avatar
Thanks a million.
As for the fuel system, I've learned too many times to 'mod just once'. Everytime I buy something, I use overkill. This helps me to always have room to grow in the future when I feel the need to go faster.... + I worked the fuel system into the deal when I bought the car from Top Level!!
Old May 21, 2008 | 11:46 PM
4kinboost's Avatar
Sorry, didn't see the question. 780's.
Old May 22, 2008 | 04:38 AM
deadbeatrec's Avatar
cant see the numbers. also what boost?
ps: i made 504whp on ics dynojet with this kit and 29psi with a throttle body boost leak.
Old May 22, 2008 | 04:50 AM
Creamo3's Avatar
What boost?
Old May 22, 2008 | 04:58 AM
slvrr's Avatar
Which ATP kit is it?
Old May 22, 2008 | 05:02 AM
4kinboost's Avatar
First pull was 335hp/303tq...10 pulls later 433hp/382tq. 28psi with no more than 10deg timing. (Just for reference, this car picked-up 17hp when I increased timing from 9deg to 10deg-- there's a ton left to go)
The last couple of weeks, I was lurking the boards and read every post, both positive and negative on this set-up. I've read all about your adventures at Dynoflash!
My set-up still has a long way to go. Still a few bottlenecks for me to free-up. That tubular header makes a nice difference with the 'restrictive' atp design. I'm running the megan for now.
Although I've been tuning my own cars since 1990 and dsm's since 96/97 the software interface with ecuflash took me a few weeks to get used to. All the xml and hex talk seemed like a foreign language the first couple of days that I got started, and I'm still growing with the software. This car would have hit 500 already if I was on AEM with no boost leak.
Please keep me updated when you go back to the dyno after the boost leak is corrected!!
Old May 22, 2008 | 05:03 AM
4kinboost's Avatar
Gt3076r with s-cover and .82a/r.
Old May 22, 2008 | 05:06 AM
the leak is fixed. it was throttle body shaft seals. now there is a slight fuel trim issue that needs to be adressed.
Old May 22, 2008 | 05:10 AM
4kinboost's Avatar
Old May 22, 2008 | 05:35 AM
tkklemann's Avatar
We'll see.
Keep in mind, it would be a good thing if he proved you wrong..
OTOH, if it didn't/doesn't, it's more knowledge gained..
It would be nice to see the possibility of it working, as it conceptually is a good idea.
Old May 22, 2008 | 05:50 AM
4kinboost's Avatar
I guess since the vac/boost leak is resolved your car should be running a little lean right?
Where are your stft's at idle? What does your o2 feedback say?
Old May 22, 2008 | 05:51 AM
i know none of this because i do not have a tactrix cable.
