a Mightier max
Old May 28, 2008 | 03:31 PM
white haze's Avatar
a Mightier max
does anybody know anything about mighty max's...i wanna drop a 4g63 in it but wanna make sure itll bolt rit up...i mite be picking up the truck but want to see its possible potential b4 i do...
Old May 28, 2008 | 03:44 PM
MrJdmJimi's Avatar
the 2.6 conquest motors works well .
Old May 28, 2008 | 03:54 PM
w3rd's Avatar
everything you need to know
everything you need to know about these swaps:
http://www.projectzerog.com/transmissions.shtml
Old May 28, 2008 | 04:03 PM
white haze's Avatar
so pretty much i jus need to get an adaptor...rite?!?!
Old May 28, 2008 | 04:10 PM
w3rd's Avatar
you can run into a lot of issues with the intake manifold hitting the brake booster, running coolant hoses and clearance for the cam angle sensor. the swap is not for the faint of heart. do some research before jumping in head first. Read projectzerog A LOT before spending any money.
Old May 28, 2008 | 04:36 PM
white haze's Avatar
so wuld it just be easier to rebuild my current motor to handle a 16g or a 50 trim...all i want is a lil extra boost to get around in traffic and/ or pulling power...jus tryin to be more nimble on my feet...non turbo is boring to drive...
Old May 28, 2008 | 08:50 PM
HeadGames's Avatar
I was going to do one..I am almost positive it is a bolt in, same motor mounts, just need custom clutch.
Old May 29, 2008 | 08:43 AM
w3rd's Avatar
with parts getting harder to find these days, your best bet is to pull the motor and turbo it. use 2g pistons and 1g rods -- the standard cheapo dsm rebuild. light machine work is required. everything from a 1g will bolt right up as far as manifolds and such go. the only question left to ask is... why? if you've ever driven a turbo max/d50 you'll wonder why the hell anyone even bothered..
Old May 29, 2008 | 08:49 AM
mitsuboost30's Avatar
check out Eric Plebani thru google hes a friend of mine and has done this swap... with "great success"
Old May 29, 2008 | 02:50 PM
jamsky's Avatar
Beware of this guy mitsuboost30, he's a SCAM!!!
05Evo8u
14
Jan 6, 2016 03:11 AM
twinturbogreg
48
Dec 27, 2010 10:38 AM
aka.ralliart15
24
Apr 30, 2009 08:56 AM
Djsilencer2k5
13
Mar 4, 2008 06:31 PM
