Ebc/mbc Or Gm Boost Solenoid?
Old Jun 3, 2008 | 02:14 PM
SPANKED's Avatar
Don't you need a little more tuning experience with the GM solenoid? Once you install one don't you need to adjust the ECU before driving?
With a MBC you can pretty much hook it up, do a few pulls, set it then head to a tuner when you have all your mods installed.
Old Jun 3, 2008 | 11:47 PM
vegas702evo's Avatar
yeah but u will still need to get tuned even after a MBC cause you'll be holding boost longer and its going to affect your a/f. The GM solenoid is the same price installed then a MBC and Reese Tuning have experience tuning w it!
Old Jun 4, 2008 | 12:01 AM
evotuner04's Avatar
15 Year MemberLikedLoved
okay either way you look at it theres diff. perspectives...so get your gm solenoid if you desire or not...i have mbc and im completely happy so it all depends what youre intensions are for YOUR car
Old Jun 4, 2008 | 08:10 AM
Inprogress's Avatar
Where can I pick-up a GM boost control solenoid from?
Old Jun 11, 2008 | 10:41 AM
kingman4's Avatar
from the GM dealer?
Old Jun 14, 2008 | 10:04 PM
EvoTio's Avatar
Originally Posted by FedEvo8
Go for the GM boost solenoid. Boost is more consistant, spools faster and doesn't spike as much. Ditched the Hallman MBC for it.
Do you have your Xede controlling your GM boost solenoid?
Old Jun 14, 2008 | 10:41 PM
Aby@MIL.SPEC's Avatar
Originally Posted by EVOLV3D
So is a mbc really that bad, i planned on getting one as it only cost about 115 dollars
its not that mbc's are soooo bad, its just you can have your cake & t it to with a ebc, especially the gm 3port
ON STOCK TURBO"S
the gm 3port or even oem ebc nay-sayers dont know how to use it to thier advantge.
Yeah, there are some people who have good luck with mbc's & there are shops/companies making loadds of cash for selling mbc's..........i dont make squat selling either, so i say what i say.
the oem emc is good when set-up correctly. the gm 3port offer consitancy of the oem ebc.
if your running a 35r, etc, a mbc will be fine, but with a ebc, you can just makes thing better.
enjoy
Old Jun 14, 2008 | 10:43 PM
www.rockauto.com
search ecu flash forum, get the pn's, whip out the cc & have the stuff @ your door in a few days.
by a tactix cable while your at it & learn to tune your stuff.
if you can read, your 1/2 way there!
Old Jun 15, 2008 | 05:28 AM
sparky's Avatar
What GM model car did the GM boost solenoid come on as original equipment?
Old Jun 15, 2008 | 05:34 AM
Evoryder's Avatar
The gm sensors are limited to a certain boost level...those running 26psi+ should get a good ebc or mbc
Old Jun 15, 2008 | 06:42 AM
Evo9tunerz's Avatar
I would disagree because of first hand experiences. There are some people I know running 28+psi and have had no problems on stock turbo using the GM BCS.
araz5260
Apr 9, 2015 01:31 PM
maperformance
Dec 16, 2014 04:57 PM
LGshow19
Mar 8, 2010 09:18 PM
jaytengan
Jul 29, 2009 07:17 AM
chinalfr
AEM EMS
Jun 5, 2004 06:48 AM
