StockVIII turbo+meth= what HP?
Old May 29, 2008 | 03:36 PM
EVOEMS's Avatar
I am thinking of adding meth to my setup. What kind of hp increase can I expect to see with the meth? Is there anything else you would consider doing before I add the meth? See my mods in my sig. Thanks.
Old May 29, 2008 | 03:49 PM
Evo8Emperor's Avatar
Search 4WheelSlide. He made 44xwhp/44xwtq. With all supporing mods, meth, and 8 turbo with 10.5 hotside and his own tune obviously.
He is also a vendor for Labonte Water/Alcohol Injection Kits. Which used to be Snow Performance who they dropped to market there product and are doing it them selves now.
Old May 29, 2008 | 03:55 PM
CA$H's Avatar
you'll need a BOV (recirc) cuz you'll be running high boost. Upgraded WGA. (thats important) I would also do a wideband .
On a dyno jet you'll be in the low 400WHP and 400 WTQ if not in the very high 3's
The Aquamist kit is the best kit.
Old May 29, 2008 | 07:13 PM
mrdevo's Avatar
---380whp with stock manifold,02 housing,rubber intake tubing,upper intercooler pipe, and injectors.---
-I'm sure with these mods and bigger cams like S2's(I have 272's), I would push over 400whp easily.
Old May 29, 2008 | 07:24 PM
scheides's Avatar
EvoM Moderator
Depends 100% on the tune and amount of boost. But add 4psi (peak) or so and you'll pick up 30whp or so. 100% worth it.
Buy the aquamist HFS-1 or HFS-5, nothing else.
Old May 29, 2008 | 08:45 PM
DG Motors's Avatar
I Just finished a tune last week on an evo 8 with an "aem" alcohol kit. Picked up 40whp and 80wtq on my Dyno Dynamics dyno.
100% M1 alcohol
Stock turbo, intercooler, and ecu
Full exhaust, intake, fuel pump, boost controller, and intercooler piping.
Old May 29, 2008 | 08:48 PM
Ultimate CC's Avatar
A solid 35-45 whp can be had with the addition of a meth kit...if your interested in one please let me know...
Old May 30, 2008 | 09:00 AM
EVOEMS's Avatar
Thanks for the info,what size injectors do you recommend?I will be getting a hard uicp later this month and an APS twin vent BOV, these should help with the higher boost.
Old May 30, 2008 | 09:27 AM
JohnBradley's Avatar
Stock injectors
We've tuned a few that made an easy 376/376 at 29psi on sprint car meth. It had a small jet in it so we couldnt push it as far, but I would think with an M10 and some big cams/cam gears (he had BC280s without cam gears...whole different subject) and more time you can see low 400's out of most dynojets. Stock compression and stock head I havent seen to many stock turbo cars make more than 430 dynojet on E85 or Racegas. Not saying it hasnt been done or cant be done, just doesnt seem to be done often.
aaron@englishracing.net
Old May 30, 2008 | 09:29 AM
m4tt VIII's Avatar
jdm ix bov, some gauges and a dyno tune should put you in the high 300's. i hit 370whp 370wtq with 9.8 hotside and greddy rs bov
Old May 30, 2008 | 10:19 AM
Azntoyhere's Avatar
Get the ETS LICP, UICP for a very cheap price. For meth get any kind of meth as long as you get the failsafe feature. Get your stocker Exhaust manifold and 02 housing ported and coated (PPI is a good vendor) or buy any aftermarket, which ever is cheaper and easier for you. Upgrade your WGA to a forge (dont really have too but better if you can). Definitly need a Boost gauge+wideband. Get it tuned for at least 25 psi. I see a lot people running 28+psi with meth and get *Tial* BOV, no point in getting a recirc anymore (Headstuds needed if you dont already got one). Get at least a 680+ injectors from Precision or HKS is fine. You will be well over 400whp. Good luck~!
voltexct9a
17
Sep 5, 2012 07:41 AM
MrEvo2nv
15
Dec 3, 2008 01:01 PM
1NastyMR
Mar 16, 2008 06:45 PM
Forrest Gump 9
16
Oct 29, 2007 06:40 AM
EvoDan2004
13
Jun 29, 2007 03:58 AM
