I think then "ics" sensor burnt up again
I think the "ics" sensor burnt up again
Ok about a month ago my ics burnt up and kevind replaced it not knowng what caused it to get fired up. So he unplugged the egr valve to see if thats the thing causing it to get burnt up. And i dont think its that. Last night my car started to act up again, idling is strange, going up and down, So what causes it to burn up? and can i take my car in for warranty?
Try not to test your meth kit at idle. A puddle of meth sits and eventually wears the sensor down.
Also and good check valve will stop the dribble after the injection process stops.
https://www.evolutionm.net/forums/sh...control+bypass
https://www.evolutionm.net/forums/sh...d.php?t=202416
The last reply mentions something about removing it, you could try PM him.
Hey Danny I think I found the fix for you.
https://www.evolutionm.net/forums/sh...d.php?t=306371
I hope this works because I think I may be in the same boat soon.
Damn bro, that sucks. I was there when you got the meth kit too. Considering that both you and I got the same meth kit and installed by the same guy..... we need to talk. LOL. =P
- John
- John
I was looking at the throttle body and I think when you have it off to plug the ics port there is enough room on that you can drill and tap a set screw on the throttle stop. Then you can adjust your idle with the set screw vs. the throttle cable.
nikkadanny
27
Jun 28, 2008 12:42 PM
