runnig problem
Old Jun 15, 2008 | 07:48 AM
will05's Avatar
Exclamation runnig problem
hey guys need some info, i just put my new clutch in and and put every thing back together. Went to fire the car up and now it will not run worth a crap i did have it tuned but i don think it would lose its tune please let me know if any has any ideas.....
Old Jun 15, 2008 | 07:07 PM
selp's Avatar
flywheel bolts, did you check them?
when you say it doesn't run?
the car doesn't start? car runs badly?
Old Jun 15, 2008 | 07:10 PM
eponti's Avatar
Need more details
Old Jun 19, 2008 | 11:58 AM
will05's Avatar
More info???????
OK guys well the flywheel bolts r good i found a boost leak on my hard pipping so i fixed it and put new plugs in it got the car to running and now it seems like it is no wanting to ideal right and my new problem is my gear slection is off and have no idea how to fix it. My question is by going to a lighter flywheel would it make it ideal different i have 280cams in it also so i am lost for words thanks for the help again guys..
Old Jun 25, 2008 | 10:51 AM
slcEvo8's Avatar
Registered User
need more info.....
ie....
by gear selection off you mean no to low pedal? Check fluid levels.
by not idling right you mean a stutter at idle throttle or isnt at the correct rpm? check all wiring connections and anything you touched on the r&r
running that aggressive of a cam will definately affect idle. No question. You need to analyze any changes you have made. What did you do to tuning to compensate for the huge cam?
thepoint4life23
Apr 5, 2011 07:26 PM
BorisTheBlade
15
Sep 27, 2008 09:59 AM
2ndnunn
12
Jun 3, 2008 12:23 PM
kingman4
37
Jan 27, 2008 10:14 AM
hang187
Mar 26, 2006 04:54 AM
