Maybe it is a dump question?
Old Jun 15, 2008 | 10:51 AM
keithano's Avatar
Hi, as most of the boost controller can store two different settings, and switch between them by just one click or so. I would like to ask is that possible to have a safe tune, and a more aggressive tune simultaneously , say 21 psi for A tune, 25 psi for B tune (assuming both A/F ratio, ignition timing are tuned properly)?
If that possible, can I run A tune for higher mpg, then switch to B tune while I am driving to extract more power suddenly?
Old Jun 16, 2008 | 10:09 PM
keithano's Avatar
No help?
Old Jun 16, 2008 | 11:51 PM
konstantinosIX's Avatar
It is one map for the boost and one for the advance for the same fuel octane (high or low) on the OEM ECU.
If you have a standalone ECU then it's one map for all octane fuels.
You can't have different advance or fuel maps to switch from a boost controller.
If you want to do something like that you have to buy a standalone ECU with different maps like 4D tuned maps switched from a button. (Motec can do this for sure...)
Old Jun 17, 2008 | 08:13 AM
evilbada's Avatar
^ +1
Boost controller only changes the boost setting (low <---> high).
That's all.
arpad
179
Feb 9, 2020 03:51 AM
c0ke
Aug 28, 2013 06:30 AM
asu11
16
Nov 15, 2012 01:08 PM
ccboy37373
Jun 19, 2008 04:14 PM
razorlab
40
Mar 10, 2008 11:19 PM
