damage to intercooler... Can it be repaired???
Old Jul 3, 2008 | 10:17 AM
Gamble's Avatar
You can try jb weld.
Old Jul 3, 2008 | 11:56 AM
cmj's Avatar
cmj
Once you fix your problem you can use a nomex shaker screen to protect your intercooler.
http://www.speedwaymotors.com/p/3545...rotectors.html
Old Jul 3, 2008 | 01:04 PM
sk8terdude929's Avatar
Have you tested it for leaks yet?
Old Jul 3, 2008 | 01:14 PM
Indy Evo's Avatar
justboosted02 have you welded one of these things? be my guest.
Old Jul 3, 2008 | 01:28 PM
bzzbee2's Avatar
I will check these out. Not sure if it would help with using the intercooler as a car bumper though... I have found that the mounting points on the intercoolers give pretty easily.
Old Jul 3, 2008 | 02:00 PM
bzzbee2's Avatar
Yes, otherwise i probably wouldnt be looking to repair it. Its leaking pretty bad.
Old Nov 3, 2016 | 04:35 PM
felixmjones's Avatar
Interesting thread, shortly after I bought my evo X I flattened all the intercooler fins with my pressure washer, due to a combination of A)never having had a car with a front mount before, b)not paying as much attn as I probably should have been, and C)failure to realise how fragile the fins are. Does anyone have first hand experience of how much performance I've hosed away? If I spend three days straightening the individual fins with a tiny blade (or less if I go insane before the third day), will the increase in grunt be worth the psychological torment?
Old Nov 3, 2016 | 07:25 PM
4b11slayer's Avatar
Nothing a good welder cant patch up.
BUT intercooler looks stock. Why not upgrade?
Old Nov 3, 2016 | 07:28 PM
4b11slayer's Avatar
Look for a used unit. XS power xs speed is great and affordable.
Just bought a used xs for 120 on clist.
Old Nov 3, 2016 | 10:23 PM
codgi's Avatar
What is with all these necro threads lately?
Slimdatwelve209
Sep 12, 2019 04:35 PM
kusk8
Dec 29, 2016 01:36 PM
CaptainSquirts
May 17, 2016 08:35 PM
