Full Blown Dual Pump System - Things You Should Know
Old Feb 22, 2012 | 04:13 PM
  #121
Drill_Sergeant's Avatar
Veteran: Army
Maybe you can use three of them? Haha.
Any luck with 6 wire fitting?
Old Feb 23, 2012 | 10:02 AM
  #122
jid2's Avatar
Most "real" bulkhead fittings use epoxy at the actual seal interface of the wires. I went through this years ago and got samples of fuel and alcohol stable potting epoxy from both 3M and Loctite through the local applications engineers. Don't be afraid....
Old Feb 23, 2012 | 12:37 PM
  #123
R/TErnie's Avatar
Do you know what you used?
Old Apr 10, 2012 | 09:54 AM
  #124
Nickolaus's Avatar
I also have this problem is this normal? should it be that full of fuel so it can flow over? how do i solv the problem?
Originally Posted by R/TErnie
Anyone have a great solution to fix the fuel from leaking out of the JB welded wire pass through?
I'm tired of this BS.
Old Apr 10, 2012 | 09:59 AM
  #125
Ted B's Avatar
Same issue here. Will have a look and attempt an epoxy solution. Otherwise, filling the tank means considerable fumes, which is unacceptable if the car is garage kept.
Old Apr 10, 2012 | 10:00 AM
  #126
Nickolaus's Avatar
Do you having both pumps running the same time?
Old Apr 10, 2012 | 10:01 AM
  #127
n2oiroc's Avatar
http://www.mcmaster.com/#liquid-tigh...-grips/=h1p1ea
part# for 6 wire. 7807K42
Old Apr 10, 2012 | 10:06 AM
  #128
Ted B's Avatar
Affirmative.
Old Apr 10, 2012 | 10:10 AM
  #129
Nickolaus's Avatar
Do you know if it should fill it with fuel all the way to the top?
I seem to have a problem. that after standing on idle for a few minutes it starts to go lean and have a pending idle. this seems to have something to do with fuel. my car is recently remaped, and the problem was also there before,
Affirmative.
Old Apr 10, 2012 | 10:16 AM
  #130
Ted B's Avatar
Filling to the top should not be a problem - ever.
Your problem appears to be unrelated. You should start a new discussion, with specifics about your system, programming, etc.
Old Apr 10, 2012 | 11:03 AM
  #131
R/TErnie's Avatar
Ted B lives
I'll be in there and fixing my fuel pump by tomorrow... I'll use some stupid crazy epoxy.
Old Apr 11, 2012 | 08:44 PM
  #132
5LEEPERISAH23I's Avatar
my full blown runs lean. im using stock wiring , no hobbs , no relay.. my FPR will not go above 35-37PSI in idle anymore then that the tack freaks out going everywhere. i have no clue what that means.. and over 3.5k hitting any boost it goes dead lean.. have no clue what to do and need help
Old Apr 11, 2012 | 10:45 PM
  #133
xsesiv's Avatar
My Full Blown DP was leaking fuel through the strands of the fuel pump wires. After several attempts to re-solder both ends of the wires to try and seal them I ended up having to cut the wires on the top side of the bulk head and solidering new wires to them and heat shrinking the join.
Been fine after 5,000 miles
Old Apr 18, 2012 | 08:47 AM
  #134
goosey2099's Avatar
Just thought I'd throw this out there While struggling with the same Leaky problem for the 3rd time, Full Blown said they have a new 3M epoxy. They resealed my pump assembly again and this stuff looks much better than the original brown stuff.
Old Jun 7, 2012 | 10:29 AM
  #135
KGB_KGB's Avatar
My car is not starting after installing the dual fuel pump? It was working fine but was running really rich ? Was about to get it tuned and now it would not even crank
Should I use a hobb? I a running a motec ecu and
