Super Evo Dyno Thread - Post your pulls and discuss!
TurboTrix and Pruven should start making copies of dyno sheets and posting them to a specific thread stating all the mods in the car and what was done.. I think that would be a great way for us to get some good comparissons without doing tons of searching
This was done a month or so ago but wanted to share on this thread. Since then
I have swapped the exhaust manifold and waiting on pulleys. Will dyno again once installed.
21psi 91 octane 5K+ feet altitude.
320hp/310tq EMS and Buschur stage four on 17psi and 93octane. Trying to spare the clutch. Just bought the Cusco though and will retune in a week or two. The car has been running 12.4@108 in Florida w/ 1.78 60ft. Those are light rolling starts at 3000rpms. Can't wait to get the clutch in.
Sup guys,
I am trying to upgrade my Evo VIII to 500 HP with 400 or so lbs of Torque. Which is the best way going about with this upgrade?
Suggestions on Turbo's e.t.c will be greatly appreciated.
Thanks!
Thanks!
Just Finish EVO7
spec: 272/272 cam with Spring valve and Ti retainer, Crower Piston& conrod, nonpolish head, IHI RX6 Turbine Boost 1.9 Bar
( On Dyno , The Boost can not keep stable at 1.9bar, peak and lower down to 1.6 bar)
12/30/04 at Pruven I dynoed my 100% stock EVO my only mod is a Hallman MBC which was cranked to an unknow number but the result was 272hp & 278tq at the wheels on Sunoco 94!
I should be hitting the track this weekend so if I can trap 105+ i will know the dyno is on.
327whp 339wtq
intake filter, turboback exhaust
272 cams, ferrea valves +1mm stock size
crower springs and retainers
safc
mbc @ 19.5psi
walb. fuel pump
valves with the 5 angel job didnt do much now but add some torque... but its planning for the future when I slap on a sexy *** turbo
cam gears and alcohol injection coming soon as well.
safc
mbc @ 19.5psi
walb. fuel pump
3071R Dyno Tuning
This is a customer's car with the following mods:
Walbro in-tank
3"turbo-back de-cat
AEM EMS
780cc injectors
ATP 3071R kit under stock un-ported manifold
HKS 272 i/e
Fidanza cam gears
Running 16psi on pump, 26psi on c-16
Walbro in-tank
3"turbo-back de-cat
AEM EMS
780cc injectors
HKS 272 i/e
Fidanza cam gears
Mods
Works Downpipe
Works 269 Cams
Works P2 Flash
Works Upgraded Throttlebody
Springs / Titanium Retainers
Bushur Catback
MR Blow off Valve
ACT clutch
Halman RX boost controller
Lightened flywheel
Testpipe
720cc injectors
SAFC2
Greddy Front mount
Injen Intake
100 octane
Works Downpipe
Works 269 Cams
Works P2 Flash
Bushur Catback
MR Blow off Valve
ACT clutch
Lightened flywheel
Testpipe
720cc injectors
SAFC2
Greddy Front mount
Injen Intake
100 octane
