Super Evo Dyno Thread - Post your pulls and discuss!
Old Apr 4, 2004 | 05:06 PM
  #121
ammitsuevo's Avatar
anyone think my numbers are off- i dont have the dyno chart up but here is the facts
244.1 hp 254 tq
mods- hks downpipe, hks mega flow, tanabe ultra medalliaon cat back- stock cat, manual boost controller set to 19psi , safc2 settings
4000 rpm - (-1)
4600rpm- (-1)
5200rpm- (-4)
5800- (-8)
6400- (-11)
7000- (-13)
7600- (-16)
I just feel like the car seems a hell of a lot stronger than my numbers
btw runs done on a dyno jet awd dyno
thanks guys
Old Apr 4, 2004 | 05:24 PM
  #122
Evo442's Avatar
Here's my dyno sheet. Mustang AWD dyno. Works P2 flash, Exhale AB exhaust, throttle body.
[IMG][/IMG]
Old Apr 5, 2004 | 11:35 AM
  #123
bpclements's Avatar
What was your AFR on that run. You might be to lean on your afc.
244.1 hp 254 tq
4000 rpm - (-1)
4600rpm- (-1)
5200rpm- (-4)
5800- (-8)
6400- (-11)
7000- (-13)
7600- (-16)
thanks guys
Old Apr 5, 2004 | 06:21 PM
  #124
ammitsuevo's Avatar
if i am not mistaken it was 12.1- the shop gave me a dyno printout without af ratio info on it- i am trying to remember what is was on the actual computer for the dyno- i do know that the tuning made the af pretty consistant throughout the entire rpm range
Old Apr 18, 2004 | 10:56 AM
  #125
GokuSSj4's Avatar
Had the chance to get the car dyno , and able to see how its doing ...
Enjoy!!!!
air fuel was at 9:5
These are the following items 3" turbo back , FMIC AVO , 264/272 HKS cams and WORKS p2 .. They work amasing ....Thanks to WORKS for their good job !!!
Old Apr 18, 2004 | 11:54 AM
  #126
Smogrunner's Avatar
Goku, we have similar mods, but I have the stock intercooler. What kind of gas were your using? I'm assuming 91 octane with such rich A/Fs. Here are my pulls on race gas and 91 octane at Vishnu's dyno. I maxed at 311whp. Who's dyno reads lower between Brainstorm and Vishnu's DD dyno?
I have turbo back exhaust, 264/272 cams with adjustable cam gears, greddy s bov, and Xedeflash.
Attached Thumbnails Super Evo Dyno Thread - Post your pulls and discuss!-dyno-results-hp-ftlbs-april-15.jpg
Old Apr 18, 2004 | 11:56 AM
  #127
Smogrunner's Avatar
Here is boost and air/fuel:
Attached Thumbnails Super Evo Dyno Thread - Post your pulls and discuss!-dyno-air-fuel-april-15.jpg
Old Apr 19, 2004 | 09:35 AM
  #128
GokuSSj4's Avatar
it was on 91 octane and at 1.2 bar (since the FMIC drops boost) with that in mine im sure over 300whp on 91 can be achieve easilly at 1.3 bar , how much boost were you running ???
Shiv's dyno reads a lot lower then a AWD dyno jet ..
its the graph on green, is it on 91 octane ? it seems that you are near 270whp on that one .. which i know shiv's reads a lot less ...
also it seems that you power peaks then it drops off , while with mine it holds till red line 7800 rpms with no drop of points ...
im sure if i was to use c-16 and boosting at 23-24 psi it would be a differnet story an a gain of 60whp .. which i have seen before with that combo ..
Old Apr 19, 2004 | 10:15 PM
  #129
Smogrunner's Avatar
I'm not sure why you ask how much boost I'm running when I posted my boost and A/F chart for all to see.
Well, let's see: I ran 275whp on Shiv's dyno on 91 octane. Add 15%, (which is conservative) to get a roughly equivalent number to Brainstorm's dyno: That would mean I would have 316whp on brainstrorm's dyno with less mods. Seeing that you got 295 and I got 316, I'll let you decide. A 21 hp peak difference.
At 7500 I am at about 298hp and you are about at 295hp: We are almost even, but we almost never drive in this range.
Now, take a look at the area under the curve: at 6000 rpms, I'm making around 310 (equivalent) hp While you are at 280. A 30 hp difference.
Now, at 5600 rpms I am making 299hp while you are at 267whp. That is about 32 more hp.
At 5000, I'm making about 283 and you are at about 255: a 28 hp advantage for me.
I just think Works left some potential very safe hp on the table.
Old Apr 19, 2004 | 10:48 PM
  #130
Audi2ptzero's Avatar
Once you start pushing the boost up you will see the peak hp start to drop down in the rpms. Right now you dont see that because your running a set boost all the way to redline, turn the boost up and the boost will start to drop in the higher rpms when the compressor wheel starts to stall.
BTW your tuner should really get you out of that 9.5:1 afr and up in the 10.5:1 to 11.5:1 range.
Old Apr 20, 2004 | 10:20 AM
  #131
n00dle's Avatar
Thanks for the comparo Smogrunner. The curve of your dyno plot shines over it all with comparable mods.
That car flashed by Works at 9.5:1 AF is probably also doing more harm by accelerating ring and cylinder wall wear by washing it down.
Old Apr 23, 2004 | 12:29 PM
  #132
GokuSSj4's Avatar
i know there's plenty of room for making a lot more hp , 310-315 whp can be achieve .. remember that since im running a FMIC (which smogrunner is the only mod different ) the boost drop to 1.2 instead of what it should be at 1.3 bar ..
so there's more potential to be made out of this car .. causing the air/fuel to be at 9.5 instead on the 10's .. the reason i dyno the car , is for this mean reason to see where the car was at .. since im not running a boost gauge ( being install this week was waiting on gauges) now with this at hand Pete will change the boost map to bump it at 1.3 bar and also with this air/fuel should change .. till the mid 10's .. will dyno again to see what gains were gain ...
Smogrunner i hadn't notice your chart or just wasn't paying attention to it ..
thats the reason i ask .... so we will see what gains were met ... i need to look at your chart to see how much tq you are making ...
Old Apr 23, 2004 | 08:36 PM
  #133
The loss in boost pressure from the upgraded IC wont cause the car to run rich since it would take a loss in air flow not boost presssure which would happen from having a leak. Now if you say you have a loss in boost this would mean you have the same pressure as others on the hot side, now if you bump the pressure up because of the loss on the cold side you will just end up over spooling the turbo and causing your tq/hp peaks to come down in the power band.
If you change the boost map your not going to change the tuning unless the IAT's come up alot which wont happen with a .1 bar increase. You or your tuner will need to lower the fuel map or add more adv timing to burn off more of the extra fuel to get you in the 10:1 range.
Old Apr 24, 2004 | 10:10 AM
  #134
GokuSSj4's Avatar
thanks for the info , since i have the dyno chart and also to what the air/fuel is reading .. i will have pete adjust it .. so im able to run mid 10's .. he will do his magic and will have the car dyno again to see where is at after the changes ....
Old Apr 25, 2004 | 11:19 AM
  #135
jj_008's Avatar
I think Goku needs to take the X-Flash Challenge.
