Walbro 255 and fuel filter
Old Jul 12, 2008 | 02:14 PM
David Buschur's Avatar
razor, post #6 is correct. The actual filter material is inside the $110 part, cut it in half and you will find it. That entire inner area is filter material like you would picture a real fuel filter to be.
The part you have is more of a screen assembly and if you look how the system is designed would not filter the fuel any better than the sock found on the bottom of the fuel pump.
We found the actual fitler assembly building modified fuel assemblies in the beginning trying to get the cars to flow more.
Now we cut about 5 of those assemblies a week.
So the real fuel filter is located in #30 in your diagram. It is not servicable.
Old Jul 12, 2008 | 02:56 PM
bank277's Avatar
Ok got it.
I'm running the Walbro 255 is there a filter in that.
Old Jul 12, 2008 | 03:02 PM
dan l's Avatar
Originally Posted by bank277
Ok got it.
NO!
As per davids first post in this thread and his second the damm filter is in a $110 part. The 255 has a stock which is simply a strainer to protect the pump from debris. The low micron filter is in the $110 part which protects the injectors and **** upstream.
Its amazing how a simple correct answer can be debated on these forums. Sorry for my attitude but just go out to your car and look at it for yourself. It kills me how many people want to be spoon fed gerbers baby food.
Old Jul 13, 2008 | 12:47 PM
RazorLab's Avatar
You mean the sock for the pick up sitting on your desk. click on the link on my last post thats the part for that part#. If it's not could you take a pic of it.
No, the filter, I've cross referenced it from Mitsu Parts Lookup I have.
LancerShop is incorrect and has the wrong price as well.
You can cross-reference it here too:
http://www.mitsubishiparts.net/cart/?pn=MB129895
Old Dec 20, 2008 | 08:06 PM
rodeo0808's Avatar
good info thanks guys. hopefully this helps with fixing my car.
Old Apr 12, 2010 | 05:45 PM
gsrIXevo's Avatar
I know this is coming back from the dead... but I had to complete this thread based on a link I found:
1 x Fuel Filter Cartridge Type
Ref : MR571545
This is the cartridge type fuel filter.
This is a lifetime filter and should not require changing unless you've broken it or put diesel in the car or some other contaminants.
Link:
http://www.importcarparts.co.uk/part...en=&searchKey=
Old Apr 15, 2010 | 01:02 AM
whitepwr's Avatar
So what happens to the fuel filter assembly when you switch to say a Full Blown Double Pumper!? Do they have their own fuel filter? Good info in here btw! I have always been curious of where the fuel filter is in these cars.
Old Apr 15, 2010 | 06:51 AM
I don't know about what other companies are doing but the Buschur Racing double pumper comes with a new SS body, 10 micron filter.
teameditevo08
Dec 31, 2016 08:19 PM
YellowEvilEvo
Aug 9, 2014 03:14 PM
04_k20a2
Feb 21, 2012 07:20 PM
Fast_Freddie
27
Apr 16, 2010 07:46 PM
