ABS light-How to reset?
Old Jul 14, 2008 | 10:17 AM
SilverEmperor's Avatar
I've had dss rear axles in my car for about a year, where the abs rings didn't match up to the sensors which threw the ABS light on. After changing the axles back to stock, the ABS light is still on. How can I reset the ABS system? (Oh the car has an AEM EMS, if that matters)
Old Jul 14, 2008 | 11:53 AM
cfdfireman1's Avatar
Did you try disconnecting the battery for a few minutes?
Old Jul 14, 2008 | 12:16 PM
Spish's Avatar
I had the same prob, just took to Mitsu and they reset it, it took about 2 min.
Old Jul 14, 2008 | 12:35 PM
PVD04's Avatar
In my experience the ABS light resets every time you start the car. I had a damaged ABS sensor wire and the ABS light would come on within 5 seconds of the car moving. I replaced the sensor and the light hasn't come on since. If your light is still coming on it seems that you may still have a problem. If you're sure nothing is wrong you can try disconnecting the battery for a few seconds to reset it.
Old Jul 14, 2008 | 01:21 PM
GTijoejoe's Avatar
Usually this is how it works. The system will go through a diagnostics, checking the function of the modulator and sensors.
Old Jul 14, 2008 | 01:28 PM
VtexGt3's Avatar
Yup. I blew the teeth off of my ABS ring before and thats exactly what it does. The car will reset everything and once you start it it will rediagnos the problem. If it comes on still then you still have a problem. You can probably use one of the ECU programs to clear the code but it'll just come bak up
Old Aug 27, 2015 | 01:34 PM
srt4fan's Avatar
ABS sensor issues
i apologize if im taking over the thread but i too have a problem on my wifes 09 lancer ES and the ABS light stays on and i have tried to pull the plug on the battery for 15 minutes, no luck and im trying to see what tools can i use or whats the best way to determine which sensor is faulty? the car drives perfectly fine i think my wife just slammed the brakes to hard 1 time, had the car brand new off the lot and this happened ruffly around 2 months ago. any insight would be helpful thank you.
TariqEvo
Jul 27, 2017 02:47 AM
Victor Sotnik
Jan 11, 2016 09:57 AM
ragyan03
Jul 13, 2012 08:00 AM
kaj
For Sale - Part Outs
Oct 2, 2009 11:49 AM
ariemcd
Aug 23, 2004 05:19 AM
