Radiator Coolant Leak From Top.
Old Jul 21, 2008 | 10:48 AM
randomevo's Avatar
I apparently have a leak in my radiator.
The reserve tank seems to drop slowly over time.
I've since narrowed the source of the leak to the top of the radiator.
It seems to just kinda pool in the cracks where the metal meets the plastic on top.
there aren't any crack in the hoses or anything.
Will post pics later but has anyone run into this problem.
Trying to determine if the radiator is shoot or not.
Haven't done a leak test but i can see the coolant seeping out of the top.
Old Jul 21, 2008 | 10:50 AM
compscibOi's Avatar
Run some purple dye in the radiator and get a flourescent light - it should show you the exact source of the leak.
GL bro, maybe time to run a Koyo...
Old Jul 21, 2008 | 04:44 PM
randomevo's Avatar
Highlighted in green where the coolant ends up.
I think it's leaking from somewhere on top and then just flowing into the cracks.
Doesn't happen all the time either. I've pushed the car hard, checked, and nothing.
I've taken a 2 min drive, checked, and saw coolant filled in where i highlighted.
Old Jul 21, 2008 | 04:56 PM
LEvo77's Avatar
yeah i have seen them leak in that area, there is nothing to do but to get a new one, some people will try to tell you that it might be welded but dont go that way
Old Jul 21, 2008 | 07:20 PM
barneyb's Avatar
The way the radiator is assembled is core, gasket, tank top and then the metal fingers are crimped over. Over time either the gasket shrinks or the metal fingers lose their tension and you have a leak.
I've heard of having the tank recrimped but I'd recommend you have someone at a radiator shop do this if you want to try it. The best bet is a new radiator.
Old Jul 21, 2008 | 07:45 PM
1slowevo's Avatar
I had the same thing happened to my stock radiator, not much you can do but buy a new one. CBRD
Old Mar 14, 2013 | 08:28 AM
AlwayzSidewayz's Avatar
this just happened to me this morning.Good time to upgrade I guess...
Old Mar 14, 2013 | 12:04 PM
barneyb's Avatar
Try a new cap before replacing the radiator.
Old Mar 14, 2013 | 01:06 PM
ReaperX's Avatar
It isn't the cap. Radiator needs to be replaced. Mine would leak when cold and for the first 5 minutes of driving, then everything would expand and seal.
Old Mar 14, 2013 | 01:27 PM
Boostfarmer's Avatar
sucks
dude same thing happened to me. If you ever see older and even some newer bikes they did the same thing plastic tops that are a weak point and almost always explode at some point from being pushed. I replaced mine with a ebay way that still uses the factory fan and I have just recently need to build the motor clearly unrelated. And have had no problems with it. Will see when it goes from 400whp to 550whp
Old Mar 14, 2013 | 01:31 PM
Sloap2's Avatar
Mine did the same thing a few weeks ago. I put my pressure tester on it and found a long hairline crack... replaced it with a koyo unit.
Old Mar 14, 2013 | 02:37 PM
barneyb's Avatar
Well, I had coolant on top of my radiator, replaced the cap and dry since. Which is cheaper and easier to replace? Unless you can see the leak, try a cap.
kwpilot
Feb 20, 2023 09:29 PM
4G63_EVO
Sep 3, 2013 09:33 AM
Spoolin4g63
Jan 11, 2012 10:53 AM
thedru13
10
Nov 1, 2011 05:40 PM
EvoTeyn
Aug 27, 2011 09:23 PM
