blew it up
Old Jul 30, 2008 | 07:06 PM
cdp1982's Avatar
blew it up
well i got 98k and i was goin home sunday night and it started knocking really bad, dont exactly what wrong. but i gotta go through the bottom end anyways might as well build it. im lookin at the ams 2.0 shortblock. my question is: is it possible to take the motor out through the top through the hood or do i hav to drop the front subframe. if i can take it out the top it will save me alot of money and i can swap all the stuff i need offf my stock block and use on the ams short block. if any1 has any insight, PLEASE let me know.
THANX
Old Jul 30, 2008 | 07:07 PM
k2boarder3187's Avatar
yes it comes out from the top
Old Jul 30, 2008 | 07:13 PM
Methodical4u's Avatar
are you really sure you want do that kind of job if you don't know how the motor comes out of the car to begin with?
Old Jul 30, 2008 | 07:38 PM
MitsuJDM's Avatar
You can do it either way. Which ever is easier for you.
Old Jul 30, 2008 | 07:44 PM
rcheung's Avatar
I have done engines before but not on an evo but most people say its easier for it to come out from the bottom.
Old Jul 30, 2008 | 08:18 PM
zx1216's Avatar
In F-body camaros it is 100% easier to drop the k frame and take the motor out the bottom. Don't hate on the guy, you are the ignorent one, it's a valid question.
Old Jul 30, 2008 | 08:23 PM
DynoFlash's Avatar
It depends on if you have a lift or not to work on.
With a lift, I like to remove the trans and transfer case and then attack the engine to a engine stand and lift the car off the engine.
This method seems to work best for me.
Al
Old Jul 31, 2008 | 01:13 AM
evo@24psi's Avatar
Someone made a post with pix a few days ago and it had a good 5 or 6 people saying it was easier from the bottom.
Old Jul 31, 2008 | 01:21 AM
tabio42's Avatar
Make sure you check your ring gap on any pre-built shortblock you buy.
Old Jul 31, 2008 | 05:37 AM
justboosted02's Avatar
yes it can come out the top, when i did it i pulled the engine and transmission as a unit.
loud knocking is probably a spun bearing, make sure you budget for all the little crap (oil cooler, oil pump, water pump, etc) cause that is the stuff that adds up fast.
also if you did in fact spin a bearing you should have your head checked out and make sure its clean and no shavings are present. you should also have it decked
you should also find out what caused the failure so it doesn't happen again, its not normal to spin a bearing at 98k and there must have been an underlying problem
Old Jul 31, 2008 | 10:17 AM
EvoX-LI's Avatar
What is your explanation of "not normal?".
98k seems like a decent amount of driving to me. There must be quite a few hard miles tacked up as well.
What is done to the car? When was the car last tuned? blah blah. There are many variables.
boost556
Jun 1, 2017 11:30 AM
Errk
Aug 20, 2015 09:32 AM
SikEvo8
Oct 26, 2008 08:31 AM
str8kor
25
Jul 14, 2008 10:55 AM
pog0
Apr 17, 2008 08:46 AM
