is royal purple causing my motor to tick?
http://www.bestoil4you.com/images/RD20g2568.pdf
http://www.bestoil4you.com/files/RD30g2569.pdf
http://www.bestoil4you.com/files/RD50g2570.pdf
TOTAL DOMINATION !
Doc
I wouldnt run RP in my car if they gave me the oil free.. I have seen many tests showing its the worst oil on the market.. If you started getting lifter tick immediately after just switching oils i would say go back to the previous oil..
Have seen posts about lifter tick around 2500 with it.. Shear is what will cause that
Use of a Higher viscosity oil Robs you of HP, Decreases your Fuel Milage and Increases Oil Temps. Could also cause excessive engine wear on cold starts including Shortening your Turbo's life.
Unless you are running loose clearances, you could benefit from running an oil as light as the AMSOIL Dominator 5W-20..
Doc
timmycat
May 30, 2017 05:30 AM
