cam gear settings
Old Jun 12, 2011 | 09:44 PM
  #136
03whitegsr's Avatar
Ported head, heavily worked intake manifold, large runner tubular exhaust manifold, 4" IC, 3" IC piping, 3" straight through exhaust... Everything to support a 35R or bigger turbo besides the bottom end but with a IX turbo cork in the way.
As I said though, the -4/0 is just what I found that worked and it may be due to the later intake closing time...or it may be because it reduced overlap. Hard to say. Either way though, retarding the intake cam is the way to go on my setup. Moving the exhaust cam hurt power every where going either direction, which was surprising.
Old Jun 13, 2011 | 04:04 PM
  #137
mlancerevo8's Avatar
i had myn at the -2/-1 like was posted and then i moved it to -4/-1 just left the exhaust where it was and i noticed a bigg difference... im thinking im goin to try and take the -1 out of the exhaust and bring her to dyno or to a spot i have and log log log get it close then pay to get it finalized...
Old Jun 19, 2011 | 09:31 PM
  #138
soo -4/0 is working awesome for power... but in 5th gear on the highway when i load up at 3-4k rpms it builds 26psi and then studders, afr goes wayyy rich... any ideas ?
Old Jun 19, 2011 | 09:39 PM
  #139
03whitegsr's Avatar
3-4k and 26 psi on the GT35 is big time surge area going by the compressor flow map. I would imagine it is compressor surge, particularly if you are using an unported compressor cover or one of the non-Garrett covers. I'd maybe consider the ECU based boost control by gear and back off the low end duty cycle in the high gears.
A related question. Is it pissing off the knock sensor below 4k RPM? When I had it on -4/0 I noticed that it seemed to set off the knock sensor in the 3.5k range considerably more often then on the 0/0 settings.
Old Jul 1, 2011 | 08:35 AM
  #140
HsamehH's Avatar
Hi Ted,
What about best midrange and spool for stock turbo 10.5 EVO 8 with Brain Crower 272 (autoX and track course).
Thanks.
Old Jul 1, 2011 | 08:55 AM
  #141
Ted B's Avatar
I don't know. AMS' testing revealed those cams appear to be well off published specifications, so your guess is as good as mine.
Old Jul 1, 2011 | 10:21 AM
  #142
jameswwt's Avatar
Omg! Long time didnt see Ted on Net....hahahaha
Kinda miss you...
Old Jul 1, 2011 | 10:53 AM
  #143
wshihdnevo's Avatar
As we have close to the same setup, I have mine at -5/0 and can tell a big difference especially compared to my dyno plot from last time at 0/0. But I too saw this same thing when messing with the exhaust cam.
Old Dec 11, 2012 | 11:44 AM
  #144
JSPturbo's Avatar
hello !! Any recommendations for degree these cams??
Thanks !!!
JUN 264
Advertised Duration 264 deg
Effective Duration ___ deg @ 1mm
Lift 10.5mm
Lobe Centerlines 110 deg Int / 115 deg Exh
LSA 112.5 deg
Old Dec 11, 2012 | 12:07 PM
  #145
Ted B's Avatar
What size turbo?
Old Dec 11, 2012 | 01:17 PM
  #146
JSPturbo's Avatar
What size turbo?
Sorry !! TD06 25g Stock Location (Kinugawa)
Thanks !!
Old Dec 11, 2012 | 01:26 PM
  #147
Ted B's Avatar
I advise advancing the intake cam 1 degree, and retarding the exhaust 1 degree (+1/-1).
Old Dec 11, 2012 | 01:40 PM
  #148
JSPturbo's Avatar
Hello!! Thanks !! Try tomorrow and show a VD Graph differences !!
Old Apr 24, 2013 | 10:07 PM
  #149
detroit pistins's Avatar
Bringing this back up…
Any suggestions on this setup?
Hta86, CB Head, S3’s, and AMS F1
Thx in advance!
Old Apr 25, 2013 | 03:38 AM
  #150
jameswwt's Avatar
Hi Ted, im back and will hope you could kindly advise me on my Gsc S2 cams setting with Gt3076R / 2.0L 8.5.1 comp
After my rebuilt some years back, ive put in S2 cams and runs with my stock Evo 5 turbo but honestly after the swap, ive no longer gets the low end response as my stock cams.
The cams were dial as GSC Spec's.
So, now im still exploring on what is the best cams setting for my S2 with Gt3076r 2.0liter engine?
How to improve response with the Cams? As before i change to Gt30 turbo, whenever i immediate full throttle my car feel very heavy and ive to immediate partial lift off and re-throttle again only than the car catapult.
Can i swap the S2 Intake cams with Evo 8Mr and Exht remain S2?
Thanks
