cam gear settings
Old Feb 28, 2014 | 05:01 AM
  #226
Ted B's Avatar
Ordinarily, yes. In your case no.
Old Feb 28, 2014 | 06:42 AM
  #227
mr evo7's Avatar
So how should I set em up
Old Feb 28, 2014 | 06:56 AM
  #228
Terror Rising's Avatar
Originally Posted by terror rising
Ted,
Currently building up my car for auto-x. I will be running an HTA71 with BC272s. I know that you say you can't recommend cam gear settings for them because they're not as published. I am planning on degreeing them to find lobe centerline so I don't necessarily care about published specs, and at that point the numbers on the cam gears are only reference points. Once I've established true centerline what is your recommendation for optimum low/mid spool without a huge sacrifice on top end?
Ted?
Old Feb 28, 2014 | 08:21 AM
  #229
foxbat's Avatar
I have a similar setup
2.3L, GT3076R, HKS 272 cams. I wonder if I should retard both -1/-1.
Old Mar 1, 2014 | 04:20 AM
  #230
Ted B's Avatar
0/0
Ted?
Then you will need a solid follower, dial indicator, and degree wheel to get an accurate measurement. Assuming you get accurate measurements, I would set the LCs at 108/110.
The intake cam is already set to a fairly late 110 deg LC, so I would use 0/-2 for that combination.
Old Mar 1, 2014 | 08:34 AM
  #231
That's the plan. Thanks for your input.
Old Mar 2, 2014 | 05:27 PM
  #232
swalltr207jg's Avatar
Ted, I'm seeing boost by 2500rpm and full boost of 24psi limited by the electronic wastewate at 4000rpm.....is this considered slow boost for the gt3071r? why? Compared too? Could you explain a little more what you mean?
QUOTE=Ted B;11130470]In both cases I recommend leaving the GSC S2's at 0/0. These cams are already timed to give best possible spool without running into issues.
In the case of the GT 3071R, that turbo spools slowly for its power potential, so it needs all the help it can get.
As for the 2.3 with PTE 6262, ordinarily, I'd recommend a couple of degrees of retard to compensate for the different piston position of the 2.3, but with an open .82 AR T3 housing, it's going to need all the spool help it can get.[/QUOTE]
Old Mar 2, 2014 | 05:51 PM
  #233
Ted B's Avatar
Not slow boost for a GT3071R, but rather the GT3071R gives relatively slow boost with respect to its realistic power potential. Because the tradeoff weighs heavily on the left side of the rpm range, doing whatever can be done to quicken spool is a wise strategy.
Old Mar 10, 2014 | 04:48 PM
  #234
URNVS's Avatar
What would you suggest as a starting point for my setup?
Cosworth 272's
GT35r .82
Built bottom end
Weekend street use and occasional trips to the strip.
Old Mar 10, 2014 | 04:53 PM
  #235
Ted B's Avatar
For Cosworth M2 with that setup, 0/-1.
Old Apr 16, 2014 | 11:56 AM
  #236
2002EVOBOYTME's Avatar
2,3L, +1mm, oem ported intake, gt3582r antisurge,maybe 272 brian crower?
Im unsure what cams i have since the seller forgot it. how can i see/measure the duration on the cams?
Old Apr 19, 2014 | 06:52 PM
  #237
420a-t's Avatar
Ted you've been doing awesome at getting back to this thread, thanks for all the info you've given.
Here's my setup, let me know what you think I should do, cam gears and do something other than what the OE gears give me:
63 block
Eagle 94mm crank
Manley 150mm rods
Manley 2.1/2.2 pistons
Block re decked .008 taken off
Head re decked .004 taken off
GSC S3'S
OE valves
Going to be running either pte 6466, fp6466, or the like. Shooting for 800whp
Old May 11, 2014 | 02:47 PM
  #238
audiofan's Avatar
Just trying to get some help, I'm building the engine to a 2.3 manley/wiseco, already have S2, but now I'm getting cam, gears, and a black BB turbo.
What setting should i go for?
Thanks for your reply
Old May 12, 2014 | 05:02 AM
  #239
Ted B's Avatar
To get the valve events back where they are with a 2.0L, you'd need to set it at -1/-1 or -2/-2, which will help top end power but soften spool. Try it as-is first.
Old May 12, 2014 | 02:00 PM
  #240
audiofan's Avatar
Thanks!
will try
