cam gear settings
Old Jul 26, 2014 | 01:59 PM
  #241
oddy_evo3's Avatar
gsc s3
hye ted can u help me..i using cam gsc s3 .turbo holset hx35 ..any idea for cam gear degree..
Old Jul 26, 2014 | 05:00 PM
  #242
Ted B's Avatar
That cam set is best suited to larger turbos and thoroughly ported heads. It has 238 degrees of effective duration and a LC of 108 degrees. In your situation, I'd probably advance the intake 1 degree and that's it. There isn't much else I would try to do with it.
Old Jul 27, 2014 | 12:39 AM
  #243
oddy_evo3's Avatar
ex set 0 degree?..intake advance 1degree
Old Dec 13, 2014 | 04:51 PM
  #244
foxbat's Avatar
Got an Evo 6, stock 2.0L with a JDM 70 series E9 Turbo (HRA-16G6mC) 22psi boost. The cams installed are BC 272. The turbo is phenomenal in terms of spool, so I'm looking to improve mid to high end power.
Any recommended cam gear settings?
Old Dec 14, 2014 | 06:24 AM
  #245
Ted B's Avatar
One significant problem with those BC cams is AMS' testing revealed they do not match the cam card, which leaves one feeling around in the dark. If they seem phenomenal where spool is concerned, that could mean they are reducing power up top. I might suggest retarding the intake cam 2 degrees with no other changes. The idle will be smoother and the spool not as sharp, but it should help top side power if the tuning allows.
Old Dec 14, 2014 | 04:44 PM
  #246
foxbat's Avatar
Actually, spool is/was amazing because of the type turbo used not the cams, since I had the turbo installed & tested before the BC cams were installed . In fact, I detected a slight delay/lag post cam installation, but it's not issue at all.
I'm going to attempt the the -2in, do a couple logs, see how it goes. Thanks Ted :]
Old Dec 15, 2014 | 12:26 AM
  #247
Siluck2's Avatar
Any suggestions for Tomei procam 270's 11.5 lift with FP HTA 71 on MIVEC?
Old Dec 17, 2014 | 05:56 AM
  #248
jameswwt's Avatar
Great Thread
Old Dec 17, 2014 | 06:35 AM
  #249
Ted B's Avatar
Advance intake cam 1 or 2 degrees for quicker spool and response.
Old Dec 26, 2014 | 12:45 PM
  #250
foxbat's Avatar
I'm assuming that all the recommended settings in this thread are crank degrees, not cam gear marks.... correct? As each cam gear mark equals 2 crank degrees.
Sorry for a total n00b question
Old Dec 26, 2014 | 03:38 PM
  #251
Ted B's Avatar
No, when we speak specifically of cam adjustments, we are speaking in cam degrees, as found on the cam gear markings.
Old Jan 22, 2015 | 07:25 PM
  #252
hung861988's Avatar
Hi Ted,
I lost 20kw after I installed the Tomei Poncam 270 in my Evo 7 (0/0 setting).
Could you please advise the setting for my below specs ?
Stock block
Tomei Poncam 270
Tomei M7960 20G Turbo
Thank you for your help
Old Jan 22, 2015 | 07:40 PM
  #253
Ted B's Avatar
20kw is quite a large loss if the car was retuned for the new cams. Please go back be absolutely certain the cams are timed correctly.
The Tomei Poncams are mild street cams with a 105 degree intake LC, which is ok for street use with a small turbo, but isn't doing much for higher rpm power. You should try retarding both the intake and exhaust cams 2 degrees (-2/-2). That will improve peak hp.
Old Jan 22, 2015 | 08:58 PM
  #254
Monkey.Magic3's Avatar
Hey Ted,
what would optimal for Kelfords tx-272, fidanzam cam gear, with a BBK-B on a tomei 2.3L, no mivec
Old Jan 23, 2015 | 04:46 AM
  #255
Ted B's Avatar
For the Tx-272 on a 2.3L motor, you should try -2/-1 to improve higher rpm power with the reduced rod/stroke ratio with this moderate duration cam set and its 107/115 LCs.
