cam gear settings
Old Mar 23, 2017 | 06:10 PM
  #301
Shinzon's Avatar
Originally Posted by Ted B
You should not need to move the exhaust cam.
The S3s will give slightly quicker spool with the intake at 0, although the short rod/stroke ratio of the 2.3 should yield a little more power upstairs with the intake at -1 or -2. The reason for this is the short R/S ratio means the piston moves faster around TDC, which has the effect of behaving as if the intake cam is slightly advanced. Because of this, a 2.3 needs the intake cam slightly retarded to give the same characteristics as it would with the shorter stroke 2.0. If you have a IX and are using MIVEC, you would simply reduce the advance a bit after the turbo has spooled.
I have an Evo 8. This is a street car hence the 2.3. what about the exhaust cams? Also do u know if these cams need to be dialed in to true zero?
Old Mar 23, 2017 | 11:25 PM
  #302
LetsGetThisDone's Avatar
Same as GSC's. Slightly shorter duration brings the useable RPM of the cam more down into the range where you'll use the 2.3 (<8500, vs >9k for the S3's), and the extra lift helps fill the cylinder better during that shorter duration, as long as you have a ported head.
Old Aug 15, 2017 | 05:32 PM
  #303
eroximus's Avatar
Can I get advice on cam settings for a 2.3L stroker with R2 cams and a EF3 turbo (I know turbo is kinda small for the build but had bought this before I impulse bought a 2.3L engine). Thanks in advance!
Old Aug 16, 2017 | 04:40 AM
  #304
Nicolas's Avatar
with hks 280/280 and M2 cossworth 272/272 both on stock turbo, the optimum was 0/0. I made at least 5 different combos with each set of cams and the result was always much worse.
Old Aug 16, 2017 | 05:01 AM
  #305
Ted B's Avatar
I like the way those cams are timed for this 2.3 setup, but 236 degrees effective duration is lengthy for that turbo. I wouldn't advise adjusting the timing unless you had an issue with spool time.
I dyno tested the HKS 280 and TME turbo setup well, and there is definitely quicker spool and a boost in torque by tightening the lobe separation angle (+2/0). I used that setting for best street performance. For the drags, -4/-1 made best top end power at the expense of some spool time.
Old Aug 25, 2017 | 11:25 AM
  #306
kev_evo1's Avatar
Originally Posted by kev_evo1
I've booked the car in for mapping on the 23rd, If they sort the lag issues via mapping what cam settings would you advise with the kelfords
Hi Ted
I never updated you on the out come of mapping
Here it is, this is with the cams set to 0,0
Better but still laggy. I since tweaked the cams +1 -1 which really did get the turbo coming in sooner
Old Jan 30, 2019 | 05:47 AM
  #307
Giammi evo6rs's Avatar
Poncam 270
Can someone help me with these cams?
0/0 is the best settings for this cams?
Old May 1, 2019 | 10:54 AM
  #308
Anybody?
I'm running evo 9 stock turbo ( on evo 6 RS)with poncams 270 set 0/0, but I want a better spool due to rally use.
Can someone help me?
Old May 1, 2019 | 12:07 PM
  #309
Ted B's Avatar
For the Tomei Poncam 270, 105/115 LCs and 110 LSA, you should try retarding the exhaust cam by 3 degrees to tighten the lobe separation angle, which is too wide for rally work. Doing this will give lobe centerlines of 105/109 and a lobe separation angle of 107 degrees. The idle will be a little choppy, but the turbo will spool and respond faster.
Anybody?
Old May 1, 2019 | 12:52 PM
  #310
Thank you very much Ted.
I will try.
Old May 5, 2019 | 09:16 AM
  #311
Hi Ted, I tried 0/-3 setup, more mid range torque but near/ same spool.
What you think about +1/-1 setup?
Old May 24, 2019 | 02:12 AM
  #312
VictorGarage's Avatar
2.3l ams
G
Hei Ted help me on this cam gear setting
AMS 2.3L
Ferrea +1mm valves in and ex
Full ferea valvetrains
Tomei Procam 280 11.5 both in ex
Full race manifold
Gtx35 AR 70
2.0Bar boost
1650 FIC
90mm Edelbrock Throttle
Magnus Intake manifold
Now producing 560awhp at +1/-1 setup
I'm going to add boost into 2.6bar and Nos shoot 100hp
Can you help me give me best setup so I won't be needing to run so many times on Dyno..
Really thank you..
Old May 24, 2019 | 09:10 AM
  #313
Ted B's Avatar
This cam set has LCs of 110int and 115exh, with a wide LSA of 112.5. You should get nominally better power at 0/-2 or -1/-2 with a 2.3L, but be aware that you aren't getting much (if any) benefit from those oversize valves, simply because the factory ports and bowls are the bottleneck that no valve can fix. Consider a CNC ported head.
Old May 26, 2019 | 02:09 AM
  #314
I will try it.. on Dyno and back you..
As for info.. I already ported head to the max.. sorry forgot to mention it before..
It is fully built engine Ted..
Old May 26, 2019 | 12:59 PM
  #315
ptitnicor's Avatar
Hi,
Can I get advice on cam settings for :
2,3l stroker
10:1 CR
Comp Cams 280
Evo 9 80 series turbo (with GTX style compressor wheel and 9 blade turbine)
Thanks
