cam gear settings
Old May 28, 2019 | 06:50 PM
  #316
VictorGarage's Avatar
Originally Posted by Ted B
This cam set has LCs of 110int and 115exh, with a wide LSA of 112.5. You should get nominally better power at 0/-2 or -1/-2 with a 2.3L, but be aware that you aren't getting much (if any) benefit from those oversize valves, simply because the factory ports and bowls are the bottleneck that no valve can fix. Consider a CNC ported head.
Thanks Ted.. I get 575whp now
Old May 29, 2019 | 05:14 AM
  #317
Viciouslord's Avatar
Good morning @Ted B
I have a 2gb GSX
Specs:
2.3 stroker
GSC R2 camshafts
2g head built by Headgames with standard size valves
T4 twin scroll GTX3582R Gen2 in a 1.06 turbine housing
What what be the best cam setting for a board powerband?
Thanks again.
Old May 29, 2019 | 05:52 AM
  #318
Ted B's Avatar
The GSC R2 is designed and timed for a broad powerband using a 100mm crank with 150mm rod length and a competently ported head. I like the timing as is, but for street use and best possible spool, I might play with retarding the exhaust cam 1-2 degrees to reduce the LSA from 112 to 110-108, although it will make for a choppier idle.
Old May 29, 2019 | 01:58 PM
  #319
ptitnicor's Avatar
Originally Posted by ptitnicor
Hi,
Can I get advice on cam settings for :
2,3l stroker
10:1 CR
Comp Cams 280
E9 turbo (with GTX style compressor wheel and 9 blade turbine)
Thanks
I hope to have a nice powerband until 7000 rpm. Do you think is possible with these cams and turbo ?
After reading your previous advices I understand I have to retard the intake to -1 or -2 ?
Thanks
Old May 29, 2019 | 02:08 PM
  #320
Ted B's Avatar
I do not know anything about the E9 turbo. The Comp Cams 280 set is good for a smaller turbo and street use, but does not have enough effective duration for the larger (e.g. GT35R) turbo setups that move the power higher in the rpm range. The intake cam would require 2-3 degrees of retard for better power, and 1-2 degrees retard on the exhaust.
Old May 29, 2019 | 02:13 PM
  #321
ptitnicor's Avatar
Thanks for your answer.
It's the Evo 9 80 series turbo. This one is modded with new wheels and anti surge cover.
The engine is in a heavy Outlander for a street use.
Old Jul 16, 2019 | 05:16 AM
  #322
Hey Ted.. if I want to upgrade my cyl head and going to solid lifter one..
What Cams is the best for me.? Is it tomei 290 ?
Or what is the most powerful cam for a Hyd lifter cams like I have now?
Thanks
Old Jul 16, 2019 | 06:39 AM
  #323
Ted B's Avatar
I'm not sure why anyone would want a solid lifter head when hydraulic heads are being used for 1000whp+ applications, but without knowing anything about the expected use of this car, turbo size, etc., it is difficult to make any recommendations.
Old Jul 16, 2019 | 10:32 AM
  #324
LetsGetThisDone's Avatar
English runs hydraulic lifters at nearly 11k rpm making 1400whp. Going to solid lifters seems....pointless.
Old Jul 16, 2019 | 11:38 AM
  #325
I see.. so what is the cams for the 1000whp+ for the Hyd lifter one ?
Old Jul 16, 2019 | 11:39 AM
  #326
Are the lifters stock ? Or GSC ?
Old Jul 16, 2019 | 01:07 PM
  #327
GSC lifters and S3 camshafts, and GSC new extra gnarly springs IIRC.
Old Jul 22, 2019 | 10:49 PM
  #328
Ted what do you say if I'm upgrade the cam into tomei 290 11.5
Last were 280 11.5
And what is the cam gear setting to start with the 290
Old Jul 28, 2019 | 06:18 AM
  #329
Last were 280 11.5
Update... Tomei no longer sell the 290
Anyone here got the cams
Old Jun 12, 2020 | 09:14 AM
  #330
Ho Eddy's Avatar
2.0L BC268camshaft 6262 precision pum gas +meth
Can you help me with cam settings?
