cam gear settings
Old Aug 18, 2008 | 09:44 AM
Nelissen's Avatar
Ted,
What do you say is the best setting for the cams?
I have a stock turbo.
Eric.
Old Aug 18, 2008 | 12:20 PM
EVOLVEU's Avatar
Id say adjust them on the dyno. Try a couple of combinations (Im sure your tuner would understand you trying to make the best power possible).
Old Aug 18, 2008 | 01:57 PM
Ted B's Avatar
I like the S1s timed just the way they are. If one were going to test it on the dyno I'd play with 0/-1 and -3/0, which should give very different results.
Old Aug 19, 2008 | 07:38 AM
Nelissen's Avatar
Ted,
so your opinion is put them in and use the oem camgear and not the adjustables?
Eric
Old Aug 19, 2008 | 08:00 AM
Ted B's Avatar
For a street-driven car with factory sized turbo, I'd say yes. Just put them in and go.
Old Aug 19, 2008 | 08:38 AM
M3EvoBR's Avatar
Any advice on Comp Cams 272 ???
3037hks turbo and hks cam gears
Old Aug 19, 2008 | 09:40 AM
Ted B's Avatar
With Comp Cams 280s, I'd to -2/-2. They are too advanced for best power.
Old Aug 19, 2008 | 05:38 PM
M3EvoBR's Avatar
and with 272 ???
Old Aug 19, 2008 | 09:53 PM
hytek369's Avatar
Ted B,
For evo 9 stock turbo and S1s, do you recommend getting cam gear for exhaust cam? I have been told I don't need it since the tuner can adjust the MIVEC for low end power, which is what I want.
Old Aug 20, 2008 | 05:09 AM
Ted B's Avatar
Originally Posted by M3EvoBR
and with 272 ???
For the Comp Cams 272s, I recommend the same thing as the Comp Cams 280s, -2/-2.
Originally Posted by hytek369
Ted B,
I can't answer that question unless I know the centerline of the S1 intake cam when at the '0' advance position. You'll have to ask Greg what it is.
Old Aug 20, 2008 | 05:18 AM
M3EvoBR's Avatar
Thank you, I'll try that, as I have -4/-2 today.
Old Aug 20, 2008 | 05:35 AM
hytek369's Avatar
does this help?
Old Aug 20, 2008 | 06:00 AM
Ted B's Avatar
No, because we do not know what "variable CL" equates to at the '0' MIVEC position.
Old Aug 30, 2008 | 04:28 PM
stockEvoIX's Avatar
Thumbs up
TedB,
I have the same question as hytek. Since the intake can be ecu controlled on a IX, and it looks like the exhaust has a 113 cl, what's your best guess as to exhaust cam timing for a IX for best midrange power? Someone was running -2 exhaust timing but had a green so it's not comparable with the stock IX turbo. Thanks!
Old Aug 30, 2008 | 05:01 PM
Ted B's Avatar
MIVEC can only advance the intake cam. It cannot retard it past '0' (the base position).
Ideally, the IX intake cam should be ground at the most reasonably retarded CL that it would be deemed useful, simply because we can advance it from that point to wherever we want with our MIVEC map. If it is ground at a setting that is not retarded enough for peak power, it's ok, but will leave a bit of power on the table, because as I said, MIVEC cannot retard past '0'.
This is why I say that it is impossible to advise possible optimum exhaust cam settings if we do not know where the intake cam CL is at the '0' position. Two cams work with respect to each's others position. If one does not know the timing of one, he cannot possibly advise on the timing for the other.
I can't guess. I don't know and have no idea. Only the individual who grinds the cams knows where he set the intake CL at the base position.
