Profec B Spec II setting question
Old Aug 25, 2008 | 07:22 PM
dafoe69's Avatar
I'm running 28psi on my BR HTA35R with a Tial 44mm wastegate(not sure which spring). My settings in PSI mode are: set gain at 280 gain at 10% and set at 72%. I'm hitting my target boost pressure but I was looking to get it there as quick as possible so there is minimal spool time. My question is will increasing the gain get it to 28psi quicker? I know increasing the gain will in turn increase boost and is more for stablizing boost drop off so should I lower my set% and in turn increase my gain? I searched but besides the basics most people are running stock turbos.
Old Aug 26, 2008 | 02:36 AM
1NastyMR's Avatar
I found when I had mine set for 10% gain or anything higher the boost would come on half of it like 10-12 lbs then the other half would kick in to hit 30 lbs I set gain to 5% and it hits 30lbs right away. I got my set gain set at 221 for 30lbs 87% though
Old Aug 26, 2008 | 06:19 AM
4G63W8's Avatar
Are you running ext.wg or internal?
arpad
179
Feb 9, 2020 03:51 AM
foxbat
Apr 28, 2013 03:23 PM
hackerrei
Aug 17, 2012 09:54 AM
Hiboost
26
Dec 30, 2009 04:28 PM
QwikEVO
May 20, 2007 01:50 PM
