Balance shaft
Old Aug 26, 2008 | 08:31 PM
gen3eclipsegt's Avatar
Question Balance shaft
Might be a stupid ? But ask anyway how do you know when the balance shaft is going bad in the motor and how bad is it to remove it I heard alot of differnt things
Old Aug 26, 2008 | 09:17 PM
Evo8luva's Avatar
the balance shaft itself probably isn't going bad, one of the bearings pressed into the block is pobably the point of failure. It doesn't seem to be a really common problem though.
Changing/ deleting the balance shafts is not going to an easy task with the motor in the car, and probably not possible without some special tools for the balance shaft bearings. And to get enough room to do all of that you are gunna have to lower the motor down really far, or just yank it all the way out.
Old Aug 27, 2008 | 01:27 PM
C6C6CH3vo's Avatar
Send off an oil sample
EvoKevinEvo
Jan 30, 2012 04:56 PM
dryad001
Aug 15, 2008 05:00 PM
sterdyevo
12
Dec 8, 2007 12:08 PM
SPOOLEDTSiAWD
75
Nov 25, 2007 09:09 AM
SaabTuner
48
Jul 21, 2005 03:37 PM
