Grease in your Forge BOV?
Old Aug 27, 2003 | 11:19 AM
NRG's Avatar
NRG
I was changing the springs for my Forge BOV the other day and when I opened it, I noticed there was reddish/black grease in there. Is this normal?
If it is normal, could you guys tell me what kind of grease it is so I can lube it up again because I cleaned it out.
Thanks!!
Old Aug 27, 2003 | 11:24 AM
camdog17's Avatar
I would suggest contacting emil at renn-art...he seems to have some good knowledge about that BOV...emil@renn-art.com
I just ordered that bov myself...keep me updated!
WannaRace's Avatar
Off topic can I quickly post a question for you...How many pounds of boost are you running to change the spring? Forge told me that even running 20psi to redline won't require the change of spring. How many psi and what spring are you using?
Old Aug 27, 2003 | 12:56 PM
ForgeMotorsport's Avatar
Mobil Synthetic Grease. You definitely need the grease in there for the valve to function properly. We recommend taking a look at the valve and regreasing, if needed, about every other oil change.
Old Aug 27, 2003 | 01:32 PM
NRG's Avatar
NRG
The question is, how much grease to put in? Does it matter if the grease gets everywhere in the valve? What exactly do we put this grease?
Old Aug 27, 2003 | 01:34 PM
NRG's Avatar
NRG
After my MBC, I want to be running 20-21PSI. Currently stock boost but the valve flutters so I am switching to yellow spring. The valve came with the blue inside. I will switch back to blue once I up my boost.
Old Aug 27, 2003 | 01:44 PM
nastea's Avatar
i use 21 lbs, and i use the green spring doesn't flutter and holds boost
Old Aug 27, 2003 | 02:41 PM
Just put a film of grease around the two o-rings in the cap of the valve. I can't explain the amount of grease but just enough to lube the two o-rings.
Old Aug 27, 2003 | 02:56 PM
WannaRace's Avatar
Well mine flutters when shifting at WOT...Plus I'd like to run 20psi to redline..BTW anyone worried about the pistons going (especially running 21psi)? Do I need the green spring Forge?
Old Aug 28, 2003 | 09:38 AM
WannaRace,
Yellow spring should be perfect. We run the yellow spring in our US spec EVO and blue in our JDM EVO 8.
Old Aug 28, 2003 | 09:48 AM
nastea's Avatar
tom, i have a question what are the tension / pressure ratings for the springs, like i stated above i use green and its fine with 21 lbs to redline...its actually quite alot quieter than the blue,
Old Aug 28, 2003 | 06:57 PM
WannaRace's Avatar
Yellow spring is aftermarket right? It comes with blue? Would I need to use the shims to tune the springs or can I just drop the spring in? How do I know when to tune? Thanks
Old Sep 23, 2003 | 05:48 PM
MYEVOVIII's Avatar
Forge what are the levels of the springs softest to stiffest has the yellow spring in and is having fluttering sound with stock car except K&n airfilter
dtenev2
Mar 14, 2016 11:06 AM
riznun
Mar 21, 2011 12:17 PM
dvd_mi
Aug 21, 2009 06:51 AM
jd888jd
17
May 8, 2009 06:47 AM
sweet03OZ
Jul 13, 2003 07:16 PM
