Grease the Oil Seals?
Old Mar 10, 2016 | 08:26 PM
dtenev2's Avatar
I re-stacked my rear diff, and now my new oil seals are leaking (I damaged one, and pushed them in too deep ).
For the second time around my question is:
Do we need to grease the oil seals with general purpose grease before installing, or do we need to have both the housing, and seal super clean?
Old Mar 10, 2016 | 08:40 PM
kaj's Avatar
kaj
I haven't done mine in a while, but don't the seals only go in a certain amount before bottoming out? I can't remember. I don't remember putting any grease, etc on the outside of the seals to install... but if helps, that would be good to know.
Old Mar 10, 2016 | 09:43 PM
LetsGetThisDone's Avatar
They are a double lip seal, you should always put some grease in the groove in between the lips that the axle rides on.
Old Mar 10, 2016 | 10:01 PM
kaj's Avatar
kaj
Mine came pre-lubed....which I found by accident, my first time (let's just say I had to then add my own, after LOL). Doh.
Old Mar 11, 2016 | 03:31 AM
shavkatjon2000's Avatar
you always grease so it slides easy without going crocked
Old Mar 11, 2016 | 08:22 PM
dtenev2's Avatar
Ok thanks guys, I will grease them again inside and outside.
Kaj they don't bottom out in the rear diff, you have to be careful not to push them in too much. You want them flush with the outside of the diff.
Old Mar 11, 2016 | 08:31 PM
You only grease the inside, where the axle rides. Not where they touch the case.
Old Mar 12, 2016 | 10:18 AM
barneyb's Avatar
These seals have a tensioning spring that on occasion will fall out as the seal is being tapped in. Also make sure there are no sharp edges on the part being inserted into the seal.
Old Mar 12, 2016 | 11:02 AM
dtenev2's Avatar
Seems like I am getting different opinions.
I know for sure to grease the axles because they spin in the seals.
But still not too sure if I should grease the outside of the seal that contacts the Diff housing.
I am leaning towards greasing the outside too, but I don't want it moving or not sealing tight because of the grease. But yes the grease will help with pressing the seal in.
Any other thoughts?
Old Mar 12, 2016 | 12:32 PM
barneyb's Avatar
I usually coat the outside of the seal with a very thin coating of RTV - avoids seepage leaks. Most people probably insert them dry. The most important thing is to use something as a driver so that the seal goes in square.
Old Mar 12, 2016 | 05:56 PM
Any other thoughts?
No grease on the outside. Either put them in dry, or with a thing coating of rtv sealant.
Old Mar 14, 2016 | 11:06 AM
dtenev2's Avatar
Thanks guys,
I will put them with a very thin coat of rtv.
I will update this post in a couple of weeks to let everyone know if it worked.
Bmurray
190
Sep 20, 2017 06:01 PM
STALIZE
Nov 23, 2013 09:21 PM
X Double Dot
Sep 10, 2013 02:56 PM
black_beauty
May 10, 2012 08:48 AM
sweet03OZ
Jul 13, 2003 07:16 PM
