Q's about Evo 9 and 8 Stock Turbo
Old Nov 28, 2008 | 06:42 AM
Jorge T's Avatar
Originally Posted by Steve93Talon
Just to clarify this point, the IX CHRA is not exactly the same, the compressor side backplate is larger. I.E. you cannot swap compressor housings between VIII and IX turbos.
They are dimensionaly the same and are interchangeable.
Old Nov 28, 2008 | 07:42 AM
Steve93Talon's Avatar
No they aren't, I've had both in my possession side by side. If they were interchangeable, don't you think alot of people would be upgrading their VIII turbos to IX spec by swapping comp. housings? I attached the best pic I can find showing the larger diameter where the compressor housing meets the CHRA.
Attached Thumbnails Q's about Evo 9 and 8 Stock Turbo-normal_evo9-20turbo-20diffuser-20compare-202.jpg
Old Nov 28, 2008 | 11:18 AM
Jorge T's Avatar
You're right i missed "compressor" I was thinking on the hotside, they are the same
Old Nov 28, 2008 | 12:32 PM
wshihdnevo's Avatar
Just to clarify also, didnt read everything word for word, but the compressor wheel size is the same on both the VIII and IX turbos, but the IX comp housing is larger...
Old Nov 28, 2008 | 01:40 PM
JYoungEVO's Avatar
Registered User
Originally Posted by whitey4d
03s and 04s have the 9.8 with the small comp housing.
05s have the 10.5 also with small comp housing
06s still have the same CHRAs as all prior usdm models with the 10.5 and larger comp housing.
all flanges and threads are housing the same just a different coolant line bolted to the comp housing and a different outlet on the housing has a lil different angle aswell so it doesnt go into the starter if put on a earlier model.
I think this is more then you needed but wanted to be clear with everything
+1
Old Apr 15, 2009 | 12:18 AM
Raceghost's Avatar
Not to resurect this thread, but...
What does this buy me?
http://cgi.ebay.com/ws/eBayISAPI.dll...id=p2759.l1259
Thanks in advance.
jid2
May 13, 2019 11:37 AM
MattJ
10
Mar 25, 2017 08:12 PM
Ixixixix
Jul 16, 2016 07:08 AM
bsbllfit7
24
Mar 5, 2016 07:58 AM
maikcat
Feb 19, 2016 01:57 PM
