Bolt on e85 tune?
Old Jul 15, 2016 | 12:36 AM
Ixixixix's Avatar
Bolt on e85 tune?
Hey guys, brand new to the evo community. Picked up a 06 mr se a while back with only 30k miles, and have been collecting parts since. I currently have a turbo xs exhaust, fmic, megan 02 housing, downpipe, invidia exhaust mani, gfb bov, injen intake. Still debating on what cat i should run/or test pipe, not my dd so whatever is more efficient [opinions please]. Basically, is it worth it to tune on e85 with basic mods and what can i expect. Any weak points on the 9? I'm sure this has been posted, i did search and read plenty. Any input or links to Any information i should be aware of will be appreciated. Thanks!
Old Jul 15, 2016 | 10:04 AM
Tekniq's Avatar
I would highly suggest a modded Walbro 255 & 1300cc or higher injectors if you plan to run the e85.
Old Jul 15, 2016 | 10:36 AM
Just the basics & a tune for approx 400+ DynoJet WHP
I would get rid of the blow off & revert back to stock. Add test pipe, standard Walbro 255 / 3 port boost solenoid / 1000cc inj or larger & a tune at 27psi max & youre set
Old Jul 15, 2016 | 12:32 PM
LetsGetThisDone's Avatar
I would ditch the cheapo exhaust manifold. Leave the stocker on there, maybe get it ported, or buy a quality manifold that won't crack. And you'll need a modded (punched relief valve) walbro 255 and 1000cc injectors.
Old Jul 16, 2016 | 12:43 AM
Ixixixix's Avatar
Bare with me . Buy why would i want to revert to stock bov? I dont have the stock manifold or bov, bought it on there already
Old Jul 16, 2016 | 05:12 AM
As long as its not venting to atmos you may be OK. If youre venting at the lower boost levels, Ive been told / read thats a performance negative
Old Jul 16, 2016 | 07:08 AM
e_kobz's Avatar
Because the stock DV is better than most aftermarket ones and it does the job just fine. And buy a cheap stock exhaust manifold, even better if its ported.
Boosted Tuning
May 31, 2015 12:32 AM
Boosted Tuning
Evo X Dyno Results
Oct 22, 2014 06:04 AM
GsrJake
Evo X Dyno Results
25
Mar 17, 2013 03:16 AM
derekste
Evo X Dyno Results
28
Oct 2, 2010 06:08 PM
