EVO 8 cylinder head
Old Sep 16, 2008 | 04:17 PM
EVO8GIS's Avatar
EVO 8 cylinder head
can a cylinder head from 06 EVO 9 fit my 03 EVO 8
Old Sep 16, 2008 | 04:21 PM
Tonba's Avatar
^ Im interested in the same thing...
I wouldnt mind a MIVEC head. What would be required for the MIVEC to function?
Old Sep 16, 2008 | 04:22 PM
IEXCELR8's Avatar
I believe it can work but you will need an evo 9 ecu for the mivec. Why not just get an evo 8 head?
Here is a thread for you: https://www.evolutionm.net/forums/sh...light=evo+head
Seems like to much of a hassle to me, but to each his/her own..
Old Sep 16, 2008 | 04:27 PM
BlackIX's Avatar
You might be able to but you would have to look into what feeds the MIVEC oil pressure. I would think it would come from an oil passage in the block which an evo 8 might not have. It may be possible to do something like a Honda LSvtec swap where you plug the oil feed hole in the head then run an oil feed line from the filter block to the MIVEC solenoid? Again I don't know for sure, just a thought, I don't know from experience how it is set up.
Old Sep 16, 2008 | 04:31 PM
IEXCELR8's Avatar
Yes all this is in the thread I linked for him.
Old Sep 16, 2008 | 04:37 PM
BlackIX's Avatar
IEXCELR8 > BlackIX
Old Sep 16, 2008 | 04:41 PM
IEXCELR8's Avatar
IEXCELR8 > BlackIX
LoL no I just think he needs to read and search to find his answer like I did.
AWD Motorsports's Avatar
I dont think all the oil passages and coolant runs the same or the evo 9 headgasket would work on the 8.. I never really researched it but i am pretty confident you cannot swap heads..
Old Sep 16, 2008 | 05:05 PM
justboosted02's Avatar
all you mechanically need to do is tap the evo 8 block for the mivec oil pressure line at the oil pressure sender. you would use an evo 9 HG.
the oil and coolant passages are the same between the evo 8/9 head/block
<--- evo 9 block and evo 8 head
Old Sep 16, 2008 | 07:53 PM
mchuang's Avatar
POST SOME PICS and VIDS of the car running!!!, did you swap ecu's or did you rewire the harness?
_des_
Apr 4, 2017 01:47 PM
badev0
Dec 20, 2016 04:24 AM
sterlinge
Nov 22, 2016 08:19 AM
ineedboostman
Apr 5, 2016 10:02 AM
socalmr
Jun 20, 2010 06:05 AM
