Taking the T-Case Out...
Old Sep 23, 2008 | 05:50 PM
binky's Avatar
Question Taking the T-Case Out...
Hey Guys-
This is my first post on EvoM-
I have a question for you all-
I am in the process of installing an Exedy twindisc clutch on my Evo8 and am having a problem taking the transfer case off.
I used a slide hammer to remove the axel from the t-case that connects it to the transmission. I am trying to use pull the t-case off now...I have tried pry bars from multiple angles and am having NO luck - it's about an inch away from the transmission and it won't go any further....
Any ideas??
Thanks!
-Bink
Old Sep 23, 2008 | 07:18 PM
justboosted02's Avatar
did you take out both output shafts?
Old Sep 23, 2008 | 07:24 PM
binky's Avatar
Hrmm, are you talking about the other shaft that comes out of the transmission? If so, no I didn't take that one out.
I didn't even think of looking on the other side- Guess that would fix it, huh?
Thanks man
-Bink
Old Sep 23, 2008 | 07:33 PM
fre's Avatar
fre
Yea, the front differential is actually in the transfer case, so both front half shafts go into the transfer case. The ***** is getting the transmission to slide away from the engine. I will probably just lift my whole engine/tranny out if I ever do it myself. It will take longer, but save me a lot of headache.
Old Sep 23, 2008 | 07:39 PM
binky's Avatar
Thanks for the info , I'll give it a shot tomorrow after work and post how it went.
Cheers!
-Bink
Old Sep 23, 2008 | 09:20 PM
huevosrancheros's Avatar
check this link out
http://evomoto.com/tech_info.php?tec...5d4068f3f99965
Old Sep 24, 2008 | 06:55 AM
binky's Avatar
Funny story - I was actually using evomoto's howto, I guess I just read it wrong...whoops-
I am at work now, I am going to see if I can get the other output shaft out and take the t-case off tonight, wish me luck!
Thanks!
-Bink
Old Sep 24, 2008 | 05:47 PM
binky's Avatar
Hey guys-
I took the other output shaft out on the transmission side and the t-case popped right out...
Ya - I feel like an idiot...oh well at least its out now.
Thanks for the advice!
-Bink
VT Mitsu
May 18, 2015 09:41 AM
jrod0187
14
Mar 9, 2010 07:47 PM
boostd97gst
Sep 22, 2009 04:48 AM
EatSleepBoost
10
Apr 19, 2008 12:13 PM
VT Mitsu
Jan 6, 2007 12:57 PM
