tilton twin installed, noises normal??
Old Oct 3, 2008 | 10:47 AM
4cefed's Avatar
I recently got this clutch installed and it fells notchy while shifting gears and makes a weird engagement sound like a loud squeak honk, just wondering if these things are normal. and does anyone where i can find the pedal stop?
Old Oct 3, 2008 | 11:17 AM
SloRice's Avatar
Tilton Carbon/Carbon?? If so, that noise is normal. It shouldn't feel notchy when shifting...it should be smooth as butter!
Pedal stop is right behind the clutch pedal. Might want to make sure you have the pedal adjusted right...could be part of your notchy shifting problem and will prematurely wear the clutch out.
Old Oct 3, 2008 | 11:20 AM
Billy@EnglishRacing's Avatar
it is normal
Old Oct 3, 2008 | 12:41 PM
Duh Panda's Avatar
its a race clutch... what would you expect
Old Oct 3, 2008 | 12:54 PM
JohnBradley's Avatar
Noise is normal, notchy isnt.
As suggested adjust clutch or the pedal stop since the Tilton uses a hydraulic throw out bearing and no slave cylinder. some of it might be the choice of gear oil and whether its been warmed up or not.
Old Oct 3, 2008 | 01:25 PM
the clutch is not very happy when it is cold, once it warms up the notchyness should go away.
Old Oct 3, 2008 | 02:04 PM
4cefed's Avatar
it's cerametallic, and the notchiness doesn't go away once it has warmed up, i was expecting some noise but that honk sound wasn't expected. I don't have the clutch stopper installed so should i get one and if so where can i get it
Fabillionaire
Mar 8, 2013 02:05 PM
redmachine
Jul 7, 2011 11:22 AM
ff-evo
12
Jan 20, 2007 09:03 AM
JakexTrainer
Nov 3, 2006 07:20 PM
ambystom01
Oct 12, 2004 09:38 PM
