10psi. . . 15psi . . . then works fine???
Old Oct 15, 2008 | 11:30 AM
xXBadAndyXx's Avatar
alrighty well that is what it is doing. obviously my car has a mind of its own. this started a few weeks back. . . so here it goes.
i notice i dropped to 15psi and tappering to 12psi. . . also i kinda bad idle everyonce and awhile.
so i looked around, and found my small line running from the bov had a nice crack in it( oh btwi have a type s BOV (recirculating) and it was making a sound like it was in the "hard" position)) anyways i replace that line and what happens??? hear is where my car gets a mind of its own. . . .
alrighty well in any gearif i go WOT it will get "stuck" at 10-11psi. then when i shift into the next gear, it will go up to 15psi, same with the gear after that.
BUT then sometimes it works just fine spikes 22psitapers abit and im on a role. . . like i said i really dont know what it is.. . . i just think my car has a mind of its own
Any suggestions
Old Oct 15, 2008 | 11:34 AM
Turbo Kyle's Avatar
Clean out you MBC if you have one....you really need to post your mods so we can see what we are working with here.
Old Oct 15, 2008 | 11:35 AM
yeah my bad. . . . ummm
tbe
gsc1 cams
Cold Air Intake
Hallman MBC
Road Tune
Old Oct 15, 2008 | 11:48 AM
Turbo Kyle's Avatar
Clean out the MBC...it has a bleed hole....make sure its not clogged.
Also do a boost leak test.
Old Oct 15, 2008 | 11:51 AM
getsideways's Avatar
Every turbo car owner should be doing boost leak tests as regular maintainence
Even minor ones can cause drivability issues , also if you continue to have issues with your boost like that you shouldnt be driving it till its fixed, you could be detonating and not even know it.
Old Oct 15, 2008 | 12:18 PM
alrighty cleaned it out. . . and actually at first inspection i notice that the bottom nipple was alread loose. . . . so i checkedit all out. . . and seems to be clean .
umm the nipple with the bleed hole. . . where does that go. . . i know stupidity on my part. . . but if you could help. . .
oh and i really dont get one it at all. . . these are just times of testing it to see if i fixed the problems fyi getsideways
Old Oct 15, 2008 | 12:22 PM
nvrmnd i figured it out with a diagram hahahah
Old Oct 15, 2008 | 12:27 PM
Glad to hear you not driving it like that ,, also what model is your hallman ,, the one im looking at right now has a small venting hole w\o a nipple on it at all.
Old Oct 15, 2008 | 12:28 PM
haha im to slow GL with your fix
Old Oct 15, 2008 | 12:54 PM
lol it all good yeah right now its my DD so it has to be reliable too . . . umm so i cleaned it out reinstalled it. . . set it too 15psi and worked in every gear. . so i turned it up 1 full circle which is about 20 psi (ish) and back to square one . . . BLAH umm so now i am going to pull the two lines off the wastegate and compressor and see where im at uugghh lol
Old Oct 16, 2008 | 04:15 AM
mhayel's Avatar
Hi everyone,
i am having the same problem as xXBadAndyXx.. however when i set up my MBC at 20psi it leaks upto 10psi. i looked under the hood and i noticed the BOV dropping oil?! assuming the turbo is dead? after a speed of 120KMH i see white/bluesh smoke from the rear but not from the exhaust, i assume the turbo leaks oil and drops on the downpipe.
any solution? or i have to replace the turbo?
Thanks,
Mohammed
Old Oct 19, 2008 | 08:05 AM
850RCT9A's Avatar
I see a lot of evo's with boost controllers hooked up wrong. Many people disconnect the factory vacumm lines from the factory solenoid and basically plug in the new boost controller. You will have problems like the ones you speak of doing it this way. The correct way to install a boost controller is to have the controller between the vacuum/boost source and wastegate/actuator. The factory lines come together off the actuator and turbo outlet. Not going to work. One vacuum line from the actuator to the proper nipple on the BC and the other from manifold pressure/ turbo outlet to the other nipple. Caps will be used on the intake pipe and factory solenoid to pervent dirt from damaging it if you want to go back to stock.
galantman03
43
Feb 5, 2017 09:54 PM
tucknroll
Lancer Troubleshooting
Mar 25, 2016 08:03 AM
lhausi
16
May 11, 2009 11:55 PM
evodave
May 10, 2009 04:57 PM
Platinum
May 6, 2003 12:26 PM
