View Poll Results: ACT Clutch? Positive or Negative?
ACT HDSS - Positive
56.38%
ACT HDSS - Negative
21.28%
ACT XTSS - Positive
8.51%
ACT XTSS - Negative
6.38%
ACT HDG6 - Positive
12.77%
ACT HDG6 - Negative
4.26%
ACT XTG6 - Positive
1.06%
ACT XTG6 - Negative
4.26%
ACT HDG4 - Positive
1.06%
ACT HDG4 - Negative
3.19%
ACT XTG4 - Positive
1.06%
ACT XTG4 - Negative
3.19%
ACT HDR6 - Positive
6.38%
ACT HDR6 - Negative
4.26%
ACT XTR6 - Postive
1.06%
ACT XTR6 - Negative
3.19%
ACT HDR4 - Positive
2.13%
ACT HDR4 - Negative
3.19%
ACT XTR4 - Positive
1.06%
ACT XTR4 - Negative
3.19%
Multiple Choice Poll. Voters: 94. You may not vote on this poll
ACT Clutch Poll!!!
Old Nov 14, 2008 | 07:35 AM
  #61
evane's Avatar
I went with the Exedy Twin HD Clutch Kit!!!!
Old Nov 14, 2008 | 07:53 AM
  #62
Mr. Evo IX's Avatar
Originally Posted by PWevo
Is it heavier than stock?
It's not heavier than stock. What is this comment about?
Also these polls are ridiculous. IHUNTV8 gives negative review for 9 of the ACT clutches. Has he really used all 9 models? I would think if I had 1 negative experience I would not repeat it 9 times ... ha ha.
Old Nov 27, 2008 | 03:59 PM
  #63
Nasty Evolution's Avatar
I just bought my evo 3 months ago, knew the previous owner of the car who had it for the past year and 10-15k. ACT HDSS peformed better than expected. Never had an issue with lock out, only a 4th gear grind above 6,500 rpm, but I think it's due to a worn syncro. I pulled the clutch last month when I pulled the tranny for inspection. It's trashed and I need a new clutch. I'm hesitant to put a new ACT in there. Last thing I want is end up with lock out.
Old Nov 27, 2008 | 04:08 PM
  #64
FastAzzEvo's Avatar
stock started slipping at 15K (went to track a lot)
act hdss with resurfaced flywheel
pedal noticeably stiffer.. Hold the power.
the bads
from around the time of install i have noticed i cant shift into 5th without letting the rpms fall some.
I also get high rpm (full throttle) lockout (like a pause in between shifts) pretty much only when racing which has made my 1/4 mile times horrible. adjustment of clutch pedal didnt' help none.
this is with stock clutchline also.
exedy twin sitting in garage, goign to pull the tranny and send it to shep for service... and i'm never goign to look back.
Old Nov 27, 2008 | 05:16 PM
  #65
JYoungEVO's Avatar
Registered User
just bought the act well see how it works out
Old Nov 27, 2008 | 09:06 PM
  #66
PWevo's Avatar
Had my act hdss/gruppe-s flywheel installed a couple weeks ago and it's been working great for me so far. Love the clutch engagement and close to stock pedal pressure.
Old Nov 27, 2008 | 10:15 PM
  #67
fireroasted's Avatar
Installed the ACT HDSS myself with GruppeS flywheel a couple months ago. Completed first track day a couple of weeks ago. Easy shifting on track, and no lockout. laps consist of full throttle shifts from 4 to 5, but I have a 6 speed. MR.
In general you tend to go for smooth shifts on track compared to fast shifts on the drag strip though.
Clutch a bit heavy, but nothing unreasonable for something that can hold the power easily. Way more clamping power than the car is producing grunt. For now.
However, I come from the Suby world of glass syncros, so I tend to be pretty patient and smooth shifting comparatively.
My stocker was gone at 10k, fyi.
M
Old Nov 27, 2008 | 10:34 PM
  #68
chad99evo's Avatar
never had any type of lockout issue. awesome clutch, great bang for buck.
Old Nov 28, 2008 | 08:57 AM
  #69
shoman21's Avatar
I have the ACT HDSS with Streetlite flywheel. I drive very aggressive and hard every day and Ive never had any problems. I love the clutch.
dsm_mikey
36
Apr 22, 2014 08:53 PM
EvoAznBoi
Jan 14, 2014 01:59 PM
evoforlife
11
Jun 25, 2010 08:37 AM
Derek888
127
Aug 31, 2005 12:15 PM
Rez90
May 9, 2005 01:14 PM
