fp green to fp red
Old Nov 2, 2008 | 09:09 AM
  #61
Shacochis06's Avatar
^^not really that was on a dynojet not a low reading mustang dyno that dynos stock IX's at 210 and cammed VIII's barely reach 300....
Old Nov 2, 2008 | 10:09 AM
  #62
jcdevo67's Avatar
to the OP...What were your IDC on pump and meth? I also have a red on the way and have 780cc injectors. I am going to run on pump for a while with the occasional 100 octane. Eventually I plan to spray meth but want to know if my 780's will cut it for a while at 28psi.
Old Nov 2, 2008 | 10:15 AM
  #63
04AWDTURBOEVO's Avatar
I am using 780ccs, and they work fine at 36 psi with the Red.
I advise to run C16 on the Red with Hi Boost.
The Red makes lots of power, and low octane can cause problems or not make enough power.
Old Nov 2, 2008 | 11:58 AM
  #64
SRT-TO-EVO's Avatar
What kind of problems? Never heard of this before. I plan on running E85 very soon anyway, but just wanted to hear the reasoning behind this since I've heard the opposite.
Old Nov 2, 2008 | 12:29 PM
  #65
The reason that you have not heard of this before is because not too many people are using the Red as of yet.
And the ones running it, are using the correct fuel for it to get the most power out of it, safely.
100 octane is not going to cut it on Hi Boost. At the power levels the Red makes at over 30 psi, using low octane fuels is not going to be safe. Specially with 780 injectors.
If you have hear the opposite, that lower octane actually is better for the Red, then thats cool.
Old Nov 2, 2008 | 01:08 PM
  #66
tony gibson's Avatar
If you are going to run e85 with the red I would get atleast 1000cc injectors.
Old Nov 2, 2008 | 05:15 PM
  #67
SRT-TO-EVO's Avatar
Lol, no but I've heard it's a great pump gas turbo (low boost obviously), but an even better one on race (high boost). I misunderstood what you were saying I guess. And thanks for the tip on the 1000's it's between those or the 1200's, but I'm concerned about drivability.
Old Nov 2, 2008 | 08:55 PM
  #68
jcdevo67's Avatar
At 36 psi with only 780's? Wow I did not think they would supply enough fuel for that kind of boost. do you by chance know what idc the injectors were at?
I am trying to decide what type of fuel to run for high octane days at the track until I either upgrade to 1000cc and E85 or spray meth.
Old Nov 2, 2008 | 09:01 PM
  #69
Evolution IVGSR's Avatar
Wow Good to know that the Red is that much better than the Green. Thanks I'm looking into the the Red for my car
Old Nov 3, 2008 | 08:08 AM
  #70
MikeyT's Avatar
This is making me reconsider the green and spend the extra and go for red. Bump for awesome results. Hope to see this around being from CT as well.
Old Nov 3, 2008 | 08:18 AM
  #71
mrdevo's Avatar
Hey Danny, I'm going to ride in this thing bro..
Old Nov 5, 2008 | 07:41 PM
  #72
fugiwara's Avatar
Originally Posted by 9sec9
Spool up is delayed on the RED by about 250 rpms, but that is VERY dependent on the tune. I made the GREEN actually get full 37 psi of boost by 3650 rpms, logged and proven. A very good tune can make the RED get peak torque by 4000. In summation: about 250 rpm later spool and 75 whp at peak.
Thanks for the valuable and detail info, this is exactly what I am looking for.
250rpm dealy in spool is not much at all right?
my tuner says the spool has a lot to do with the cams used. if one is using HKS 272 and another one is using fp5r, the one with HKS 272 will have better spool
Old Nov 9, 2008 | 10:59 AM
  #73
addo's Avatar
I have gs1 cams and will be getting a Red. i know that higher lift cams like GS2 or m3 cams would get better out right power but will me gs1 help spool?
Old Nov 9, 2008 | 11:49 AM
  #74
yea definitly...the s2s or m3 well give u alot more topend tho...your s1s are fine tho but you can always upgrade as well
Old Nov 9, 2008 | 02:09 PM
  #75
mudduck's Avatar
s1's will be too small for the Red...
