fp green to fp red
Old Nov 9, 2008 | 06:17 PM
  #76
High_PSI's Avatar
Originally Posted by mudduck
s1's will be too small for the Red...
How do you know that?
Old Nov 10, 2008 | 12:02 AM
  #77
yikez's Avatar
bump!
im also about to order the RED but i have the S1 cams .. don't know if i should upgrade or not..
Old Nov 10, 2008 | 12:15 AM
  #78
RoadSpike's Avatar
Forced performance basically said you need bigger sticks than the s1's to get the "most" out of the red. Hell that's true with any turbo...
If you got s1's see what you can do with them before tossing them out. Why spend the money if you may be happy with the results...
Old Nov 10, 2008 | 07:51 AM
  #79
FastAzzEvo's Avatar
think cosworth mivec cams 272/272 will be good for a red on pump
are 780's good for a red with meth at about 30psi?
I plan on running pump on the street and possibly getting meth in the spring...
Old Nov 10, 2008 | 08:05 AM
  #80
Shacochis06's Avatar
I would just go with the 880s then if you want to run meth...
I think the m2s are the smallest I would go with a red..
Old Nov 10, 2008 | 09:08 AM
  #81
-Evo Aaron-'s Avatar
FP turbos FTW
if i ever ditch my stock turbo ill go for the FP green witht the 18 psi hp actuator
Old Nov 10, 2008 | 09:09 AM
  #82
FP turbos FTW
FP green and the red are both sweet
Old Nov 10, 2008 | 10:53 AM
  #83
zedevo's Avatar
So after readin 6 pages, Ill Suggest to wait little bit to see wath is the good and bad effect of the RED, I have a BRAND NEW green still in the box with all the options as 18PSI , Ported & C.COATED, Install kit etc ...
Any I can understand well that the RED is the same as the GREEN on PUMP GAS but the RED work very hard and strong ON RACE GAS ... Hope if some prove that im wrong ... Hope that ill not desapointed for buying the GREEN ...
THX GUYS ...
Old Nov 10, 2008 | 02:55 PM
  #84
JK@THESHOP's Avatar
Originally Posted by onesexyevo
i just got a fp green 3 months ago my car put down 432 whp 390 tq with meth 28psi.now i just upgraded to fp red and holy **** what a difference 509whp 450tq31 psi i had to lower the boost because im running stock internals and stock clutch dont want to blow it up!! i give fp red two thumbs up
Danny glad to see your happy with your results , just to set the record straight it was a bit more boost then the 31 psi stated , it was more like 33 or so , but yes we did indeed turned the boost down to 27- 28 psi because as Danny stated he is on stock internals - Jimmy
Mikey@Spec-Ops
92
Dec 12, 2011 09:47 PM
RSMike
49
Jun 22, 2011 04:37 PM
CHICKYEVO
11
Oct 27, 2010 10:14 AM
kemoly
31
Sep 4, 2009 09:02 AM
DarthSuperShado
26
Jul 31, 2009 07:38 PM
