help ,,,
Old Nov 3, 2008 | 11:47 AM
haseeb's Avatar
help ,,,
hey ,strange thing hapend today ..im already facing some power shifting problen when racing , geting back to home after some hard pulls, i got in the reverse gear to park da car when i lift of da clutch padle to get moving i felt somthing draging and da car is slightly moving wid minor hops ..dificult to explain but its like ive already had hand break on and trying to move .than i get in neutral 2 ,3 times ,now my car is normal .is it the cluth draging or ny thing else .sory for bad explanation though .
Old Nov 3, 2008 | 10:00 PM
haseeb's Avatar
bump
Old Nov 3, 2008 | 10:09 PM
EvoHung's Avatar
Might wanna check your bushings. Tranny fliud might need to be changed. And sometimes you have to wigggle around in neutral or even shift into 1st gear first before you can make a clean shift to reverse.
Old Nov 4, 2008 | 12:23 AM
haseeb's Avatar
the shift to reverse is excellent ....this did happen in the 1st gear also ....
somthing is dragging and than gets normal ....it happens when im moving the car not when im shifting ...
i doo have problems in shifting during races ,just wondring if this is due to clutch also ...
also tell me that wat do u guyz say about mobile tranny fluid or zic as this is the only fluid available in my country
Old Nov 4, 2008 | 12:26 AM
4g63smokinall4s's Avatar
All those suggestions sound correct.. except the first to reverse..
you want to go into second then go to reverse.. its on the same cable and helps it out alil..
1st to revers wont do anything
Old Nov 4, 2008 | 07:40 AM
EvoHung's Avatar
I have always used 1st to reverse but if 2nd to reverse is the correct way then try it that way. But if it feels like its dragging after being in gear already...hmm...have you tried adjusting your clutch engagement?
Old Nov 4, 2008 | 08:49 AM
haseeb's Avatar
il give it a try also
Old Nov 4, 2008 | 08:51 AM
OhsixIXBish's Avatar
is that written in english?
Old Nov 4, 2008 | 09:19 AM
haseeb's Avatar
yea kind of .
