Oil cooler delete
Old Nov 7, 2008 | 01:49 AM
gudmundur's Avatar
Oil cooler delete
Hi
I have seen some information about people deleting the oil cooler.
I understand that if you do road racing or some form of time attack that this wouldnt be a good idea.
But what about normal daily driving and quarter mile runs ?
All information on this appreciated
Gudmundur
Old Nov 7, 2008 | 04:30 AM
scorke's Avatar
Unless your worried about saving a couple pounds I see no reason to EVER delete this...
You could also remove the radiator....
Scorke
Old Nov 7, 2008 | 05:20 AM
Whoop_ass's Avatar
Take out your Intercooler you won't need that either LOL!!!!
honestly unless you live somewhere were it is very very cold i would not remove it.
Mitso put it there for a reason...
Old Nov 7, 2008 | 05:42 AM
Exciting News's Avatar
Well, he lives in Iceland so it must be cold right?
Op, just take it off and monitor your temps. You could always put a duct to the oil pan where the cooler was. It's still a sill idea.
Also, if you've seen some information on people deleting the oil cooler then why are you asking us?
Old Nov 7, 2008 | 07:17 AM
nos51's Avatar
i dont see what the problem would be daily driving it.i drive in miami traffic like every other day and i havent seen no ill effects.if you were road racing i could understand.you will be just fine.
Old Nov 7, 2008 | 07:23 AM
lancer2show's Avatar
you must mean greenland
Old Nov 7, 2008 | 08:56 AM
Ted B's Avatar
Some BMW motors use an oil cooler thermostat assembly to switch the oil cooler on only if the oil temperature exceeds 100degC. If you find that the oil temperature is always low, then it should not be a problem to remove the oil cooler. In a very cold climate, eliminating the oil cooler may be a good thing. It is important to have the oil reach the proper temperature.
Old Nov 7, 2008 | 09:00 AM
JohnBradley's Avatar
Lucas has been running around without an oil cooler since he built the black car and it doesnt affect it in normal driving and drag racing. Road course stuff might be different but I wouldnt worry about 80% of the rest of the car's life.
Old Nov 7, 2008 | 09:17 AM
gudmundur's Avatar
Well it doesnt get really hot here and we dont have a road race track so Daily driving and drag racing are the only activities that my car sees.
I have heard about a few cars like a few of the Buschur built cars and now the one Lucas has that have done this.
So there is no other reason to do this than saving a few pounds.
On a side note I was mostly curious because I have seen a few successful cars that this was done on.
Old Nov 7, 2008 | 09:48 AM
SloRice's Avatar
remove it. Not necessary for what you are doing.
I also plan on road racing it next year and I don't have an oil cooler. Oh noes....
Old Nov 7, 2008 | 10:01 AM
BiFfMaN's Avatar
Ohio does not even get close to hot.
Try without a cooler on a road course here in nevada.
Old Nov 7, 2008 | 10:28 AM
MustGoFaster's Avatar
I wouldn't bother removing it. Unless you work on the car a ton and hate dealing with it all the time.
Old Nov 7, 2008 | 01:33 PM
SloRice's Avatar
It's you're own fault you live in the desert.
I could care less about running my car with or without an oil cooler in NV because I don't live there.
Also...I have some interesting test data of oil temps with and without the cooler. You'd be surprised.
Old Nov 7, 2008 | 02:16 PM
sprx19's Avatar
I really don't understand why you would remove it. It weights almost nothing and can only help the engine. The only reason I would remove it would be if I blew the engine up. In that case I would be concerned about debris in the cooler. I wouldn't spend the money to replace if I had to get rid of it.
Old Nov 7, 2008 | 06:35 PM
EVO8emUp's Avatar
Our cars have this valve. Its on or near the oil filter housing, IIRC.
You can raise and lower the closing point of them by switching valves.
http://www.rostravernatherm.com/
