Stock Limitations and GT35R
Old Nov 10, 2008 | 04:14 AM
tumtum411's Avatar
A lot of good advice
Old Nov 10, 2008 | 06:06 AM
jamevo8's Avatar
wow this site has grown up! 2 years ago all you would have heard was (search). Nice to see alot of help rather than flaming
Old Nov 10, 2008 | 06:21 AM
Dragking2189's Avatar
I also have a 35r, double pump, 1000cc injectors . Will this injectors do da job or have to upgrade to 1600cc?
Old Nov 10, 2008 | 06:27 AM
I also have a gt35 and have 1000cc injectors and dual pump can I tune on e85 with this injector without having to upgrade 1600cc injectors
Old Nov 10, 2008 | 06:57 AM
psphinx81's Avatar
twin pumps and 1000's will be MORE than enough
Old Nov 10, 2008 | 07:21 AM
Ph3n1x's Avatar
Search
Old Nov 10, 2008 | 07:28 AM
Aby@MIL.SPEC's Avatar
i dont know how much power the oem rods can handle.....
however, i wouldnt recomend spinning the motor with oem rods much past 8k @ high power.....this is only based off of people reportedly spinnig their motrs to ~8,500, then shortly after spinnig a rod bearing.....
yeah, there are lots of people out there who have taken their motors past 8,500without issue........how lucky do you feel?
Old Nov 10, 2008 | 08:10 AM
jdmuscle's Avatar
Well, all I wanna do is make 500Whp reliabily. just need the appropriate supporting mods to do this without hurting the motor or pushing the limits in my car....for all the crazy racing I have my supra...LOL
Old Nov 10, 2008 | 11:09 AM
Mellon Racing's Avatar
Originally Posted by psphinx81
yes, i run mine on a stock ecu. i suggest mellon tuning as a tuner, hes amazing at what he does.
EGT boost and wideband are good, i would suggest oil pressure too, but thats just me.
thanks for the mention
Old Nov 10, 2008 | 03:00 PM
ETS Michael's Avatar
Originally Posted by Meeh Lucky IX
I'm currently running an ETS PT61mm stock bottom end and ecu @ 500.4whp 407.6wtq on a Mustang Dyno on e85
Clutch - Devo/Quarter Master Twin Disk
ETS 3.5in Widetank Intercooler
Fuel - DeatschWerks 1600cc Fuel injectors, Bosch 044 Fuel Pump, and Aeromotive Fuel Presure Regulator
Axles are pretty stout on the Evo realy don't think you'll need them unless you are pushing a crazy amount of power
This is the same setup I would recommend. We made 599 to the wheels on a stock block w/ rod bolts and S2's on a PT61 using a 2.75" intercooler (We left a ton of power on the table with this small intercooler) I would highly recommend going with a 3.5" or 4.0"
Thanks,
Michael
Old Nov 10, 2008 | 03:20 PM
Meeh Lucky IX's Avatar
Thanks,
Michael
With my setup that ETS Michael quoted above, we also left some power on the table as well, we made that 500whp at only 28psi of boost usually we would be about to pull around 30 or 30+psi of boost but we wanted to keep the car safe because we felt that 500whp on a Mustang Dyno here that reads like Buschurs is pushing the stock internals.
Hey Michael your 4088r Turbo Kit has my eyes on it right now was thinking of trien to pull some single digit runs for the next season : )
Old Nov 10, 2008 | 03:23 PM
You and me both =)
Old Nov 10, 2008 | 03:27 PM
RazorLab's Avatar
Don't you need to run faster than 11.7 with your current setup first.
I want to see a 10!
Old Nov 10, 2008 | 03:41 PM
I want to see a 10!
Hehe of course we gotta run a 10 before the setup is to be changed I think we'll be trailoring the car up to Sac Raceway this Wenesday to hopfully pull it off, as long as I get a few runs in and the techs don't nag about anything I should be able to do it if I get 4 or 5 runs and don't break 10's i'ma just have to slap myself.
tc17
15
Dec 23, 2008 08:53 AM
southpaw
32
May 8, 2008 05:22 PM
boost<3
11
Sep 1, 2006 03:33 PM
3000ways
23
Mar 9, 2006 01:12 PM
Turbojunkie
Feb 15, 2006 05:23 PM
